6.7 Radiator Leaks
Ours went out with around 60 000kms I believe but it was under warranty. Now with 170000 on it I'm just waiting for it to go again. Good news is Rockauto has them for a good price. Motorcraft was around $500 CAD and the spectra was a little more. Anybody try a spectra one yet? Better than the Motorcraft?
I'll be installing a CSF brand radiator in a customers 2011 F350 Monday. We'll see how that goes. I installed a Carquest one in a customers truck back in March and it has been great so far. One thing we do know is the Ford one fails so trying another brand can't be a bad idea. Plus the warranty on the aftermarket could be better than the Ford Motorcraft. Just my $.02
I'll join the club, mine started leaking along the tank yesterday, 41000 miles and only 16 months old. Makes me real confident for the 800 mile drive I have tomorrow. Probably won't be covered which is expected. With all the other problems the truck is starting to have its time to trade. The powerstroke has left a bad taste in my mouth recently.
Ford Motor Company needed to hit a homerun with the newest diesel and for the most part they did but with all the issues customers have had previously with the Super Duty trucks prior to 2011 they are on very thin ice. My truck has been issue free other than a failed EGT sensor left me stranded. I know of several folks in my area that have had radiator problems to the tune of $1300-$1700. I am on the fence about trading mine if it begins to leak but if I replace the radiator on this truck, I'm done with FoMoCo. $10,000 diesel motor with a $40 radiator.
One thing I have noticed over the years.......pretty much EVERY generation of truck, regardless of brand, will have some sort of weak link. Some are worse then others, but by abandoning "brand A" to go to "brand B" because of a simple problem makes no sense to me. Nobody makes the perfect truck!
I have been a 7.3 guy for years, and they most definitely had their weak links. Mainly the CPS, Up-pipes, and not so great transmissions. I addressed all of those concerns, and had a truck that was virtually bulletproof (pardon the over-used term). I am new to the 6.7, but I did my homework over the years, and from what I have determined, it is a GREAT truck, and motor, and over all a LOT better vehicle than the other "Big 2" in the diesel game. There will be some bumps in the road, but they are to be expected
I have a 2017, traded a '15 Ram Cummins, the Ford is night and day above the Ram, in many aspects. Love the 6.7L PSD, will run circles around the Cummins.
Remember the Howie Long commercials showing how badly the Ford flexes it's frame? Well, when the frame flexes it tugs at the radiator which is directly or indirectly mounted to it. Yes, there are rubber radiator mounts but they can only move so much. The front section of the frame is fully boxed which will help it some, but I'd reckon this is the problem. Even the expensive Mishimoto radiators fail in the same manner. A better solution would be to figure out a way to mount the radiators that give the mounts more room to travel.
I'm hoping the 2017 trucks have solved the problem with the fully boxed frame resulting in less flex.
I just traded in my 2013 for a 2017 and the frame is noticeably stiffer.
The secondary radiator has a thermostat located in each of the left and right tanks. The right is a 140F thermostat and the left tank is a 113F thermostat. I think the OP is talking about his primary radiator as being what's leaking.
I don't think he's saying the primary has thermostats, just that the thermostat is having a effect on the primary radiator.
That might explain why some vehicles seem to have a consistent problem with radiators (I'm on my 3rd Mishi) and others don't. If it was a frame flex issue you would think it would be more common with heavy service uses, i.e. oil fields, farm use, etc. While I do some off-roading, nothing extreme. My leaks have started without being off-road, just heavy traffic, highway miles, with or with out a camper.
