Mysterious disappearing Trans fluid
I did a complete flush following the tech folder instructions a few months ago. I filled system with redline d4. Ever since I have been about a quart low when I change my engine oil and I recheck fluid levels. Trans and pan are bone dry underneath the truck, where could the trans fluid be going?
I am a little confused, you did the flush a few months ago and check the level when you change your oil ? either you change your oil at very short intervals or I am not seeing the timeline correctly.
How many quarts of ATF have you added to it since you did the flush and how often did you need to add ATF ?
Oldguyfl, I wish I could check but my other issue is a leaking radiator. My ex had a puddle of coolant under it yesterday. Leak is at the top where the plastic and metal meet. I was able to get home because it still hold coolant, but I loose some once engine is up to temp.
Jumbo, I'm not sure how to check transfer case oil level. Sadly that would mean I haven checked it in about 2 years.
If you're a quart low, add a quart. What happens when you do? Does it lose another quart? How long does it take to lose that quart? Does it lose more than a quart if you wait longer?
Stewart
Pirate, it was just the timing. I did the trans fluid change, about a week later I did my oil change and checked the trans fluid, I thought I must have under filled so I added a quart and it was up to level, then about 2 months later I took the kids on a road trip, I checked my fluid levels before we left and I was a quart low again topped it off before we left. Did oil change when we got back, quart low again in trans. 3 quarts over 3months and about 4K miles mostly hwy driving, but the Ex is my daily driver.
Mark K, Good to know! I know I need to change my radiator (see my radiator leak post) also I should check my transfer case since I haven't done it in 2 years. What am I looking for to determine if it is the tranfercase? Foaming oil or just over filling? I will need to check the tech folder to learn jow to service it.
How closely have you looked at the underside of your rig?
The seal in my transfer case was leaking, allowing fluid to migrate from the trans to the transfer case, and it was replaced when I had John Wood freshen up the trans.
Stewart
