It's hot ,I need air
Hello all, I'm new to fte but have been gleening infomation off this site for a long time. I have a problem that I hope I can get some help with. I have a 81 f 100 that had dealer installed air conditioner put in when new. Everything has worked fine until this week. I have determined the fan motor switch has gone bad. Being dealer installed it has 9 flat pins on the back,5 straight up and down on one side and 4 on the other. I have not been able to locate it anywhere so I have come to the only place I know to get help.
Thanks,
scED
Thanks,
scED
Is it anything like this one on eBay?
Ford Truck Dealer Installed Economy Air conditioning control switch panel | eBay
Does your system look like the schematic/parts breakdown in this link? There are some numbers in there for the switch.
https://www.ford-trucks.com/forums/1...alled-a-c.html
This is the only dealer installed A/C blower switch listed for these vehicles: 1980/82 F100/250, Bronco & Econoline.
Also: 1971/72 Capri, 1972 F100/350; Econoline; Galaxie/LTD; Torino; Mustang with dealer installed "hang-on" A/C
1973/79 Ford/Merc Passenger Cars with "hang-on" dealer installed A/C
1973/79 F100/350, Econoline & 1978/79 Bronco with dealer installed 'in-dash' A/C
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 13 = 800-476-9653.
IMO, since this dealer installed switch (D1RY-19986-A / Motorcraft YH-210) has the wrong number of terminals, the OP's truck has a gypo aka aftermarket A/C installed by an A/C shop.
Plus, the number the OP posted off the original switch (post #6) is not FoMoCo related.
Take the switch and gently open the metal tabs and pull off the contact board. You should be able to clean the contacts or reveal the problem after you get it apart. Be careful in case there is a spring inside and notice its position. reassemble in reverse. The metal should be soft enough not to break off but don't bend them back to quickly or all the way back ... just enough to get the board off.
