It's hot ,I need air
Old 08-17-2017, 06:35 PM
scED's Avatar
scED
scED is offline
Hello all, I'm new to fte but have been gleening infomation off this site for a long time. I have a problem that I hope I can get some help with. I have a 81 f 100 that had dealer installed air conditioner put in when new. Everything has worked fine until this week. I have determined the fan motor switch has gone bad. Being dealer installed it has 9 flat pins on the back,5 straight up and down on one side and 4 on the other. I have not been able to locate it anywhere so I have come to the only place I know to get help.
Thanks,
scED
Old 08-17-2017, 07:45 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,182 Likes on 1,854 Posts
Welcome to FTE.
Can you post up a picture of this switch?
Someone may know where to get one.
Dave ----
Old 08-17-2017, 08:34 PM
Braggs's Avatar
Braggs
Braggs is offline
Another option is to hotwire the blower motor. Then when you turn the air control to any setting it blows like it is on high.
Old 08-17-2017, 10:33 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
A picture of the switch along with any numbers embossed on it, something like
E0TA 12345 AC
Or any similar identifying markings, and maybe somebody can locate an actual plug-in replacement.
The wiring can be modified and different technology installed, too.
Old 08-18-2017, 10:02 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Old 08-18-2017, 04:44 PM
scED's Avatar
scED
scED is offline
no I am afraid not.Mine has the lever instead of the **** and 9 pins. It has a part number ,031-7196 and UID on each side. It is a 4 position switch,off,low,med,and high. ,
I will get a picture as soon as I can get grandkids over.
Thank you for helping,
scED
Old 08-19-2017, 01:02 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
David - I wonder if somebody already swapped in some sort of aftermarket replacement and some weird configuration... that happens sometimes....
scED - Yes; pictures, please.
Old 08-19-2017, 07:47 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,741 Likes on 1,411 Posts
Does your system look like the schematic/parts breakdown in this link? There are some numbers in there for the switch.
https://www.ford-trucks.com/forums/1...alled-a-c.html
Old 08-19-2017, 12:13 PM
scED's Avatar
scED
scED is offline
Yes it looks similer but my switch fastens to the control with 2 screws on the right side of the switch.
scED
Old 08-19-2017, 02:33 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
D1RY-19986-A.. A/C Blower Switch-Use with dealer installed A/C without Integrated Controls (Motorcraft YH-210) / Obsolete
This is the only dealer installed A/C blower switch listed for these vehicles: 1980/82 F100/250, Bronco & Econoline.
Also: 1971/72 Capri, 1972 F100/350; Econoline; Galaxie/LTD; Torino; Mustang with dealer installed "hang-on" A/C
1973/79 Ford/Merc Passenger Cars with "hang-on" dealer installed A/C
1973/79 F100/350, Econoline & 1978/79 Bronco with dealer installed 'in-dash' A/C
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 13 = 800-476-9653.
Old 08-19-2017, 02:36 PM
Franklin2's Avatar
Franklin2
I get a lot of hits for Motorcraft yh-210 in the internet. But it only has 5 terminals on it.
Old 08-19-2017, 02:42 PM
NumberDummy
I get a lot of hits for Motorcraft YH-210 in the internet. But it only has 5 terminals on it.
Parts catalog does not list the number of terminals for this switch. Thank you for posting this info.
IMO, since this dealer installed switch (D1RY-19986-A / Motorcraft YH-210) has the wrong number of terminals, the OP's truck has a gypo aka aftermarket A/C installed by an A/C shop.
Plus, the number the OP posted off the original switch (post #6) is not FoMoCo related.
Old 08-19-2017, 02:58 PM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
If the origainal part is not available, it shoud not be too dificult to add another switch just to control the Fan. If that is all that is wrong.
Does the AC work other than the fan doesn't come on (or Fan is on low speed)?
Old 08-19-2017, 03:57 PM
scED's Avatar
scED
scED is offline
the bottom orange,red and yellow wires go to the AC fan and the orange, red and yellow wires on top go to the factory plug for the heater and defroster. I found the paper work for the AC but none of the numbers work.
Old 08-19-2017, 04:24 PM
byronbgs's Avatar
byronbgs
byronbgs is offline
Take the switch and gently open the metal tabs and pull off the contact board. You should be able to clean the contacts or reveal the problem after you get it apart. Be careful in case there is a spring inside and notice its position. reassemble in reverse. The metal should be soft enough not to break off but don't bend them back to quickly or all the way back ... just enough to get the board off.
Quick Reply: It's hot ,I need air
