5th wheel hitch question
Hello, new member here. Always read post from here but just recently joined. My question is I just got a new 2017 f350 and I need to get a new hitch, are any of you having problems with bed height clearance? I've got the factory prep installed and I'm leaning toward the b & g companion. What are you guys using with this set up and how do you like it? My old hitch was a slider and I'm looking forward to not having all that weight to lift out of the bed.
If you already have the puck system in your new truck, get the goose box system - if you want to install the standard old rails, get the rail mount system: see here - https://andersenhitches.com/catalog/...onnection.aspx
This REALLY saves your back installing and removing.
If you have the factory pucks, the B&W is a nice combo to go with that truck. As far as bed height, you really just have to check your truck to your choice. The truck will level out somewhat. If it's an F250, you should be fine. If it's an F350, you may need to 'play' with the rear spring blocks, changing to the F250 2" version, along with hitch adjustments, of which the B&W has several possiblities. Lots of these new trucks pulling 5ers with no problems.
Do it - you'll enjoy!!
Guy I got my 5er from gave me husky hitch and rails. I had in bed turnover ball factory installed in the f-350 so I purchased Curt X5 5th-Wheel Base Rail Adapter Plate. Very sweet setup as you can remove all when not in use and not have permanent rails mounted! Believe it or not I got the best price for the adapter on walmart.com
While everyone has their favorites, the Andersen Ultimate mounted to a goose ball replaced my Reese 16K and I've never looked back. Take the AUH off the goose ball, pop the goose ball out and I have my bed back.
