more Flathead questions
OK, I went and bought a 47 in-line six.
It is the engine, and driveline but no rear end. There is a torque tube.
I bought it basically for the drive line and I couldn't turn it down.
My question, the bell housing is cast, Will the bell housing, Flywheel, clutch, and tranny work with an H series in-line six?
The transmission is a three speed Side loader
Yes. Mostly when it comes time to change the clutch or do tranny work, you have to remove the rear axle. Mostly it's a matter of having a completely different rear suspension and frame. Parts are expensive for them, too.
I assume the driveline and engine are out of a car? You can change the trans to be like our trucks' (open driveline) by changing the main shaft and rear bearing retainer.
This picture seems to match
the '47 bellhousing is now mounted on the '49 engine.
the '47 trans has a cast in cover that closes the back of the bellhousing.
Nothing should. If you click on the scale icon just above the green bars on the member's message you wish to acknowledge a dialog box will appear allowing you to add to their reputation. Thanks for asking.
