OK, I went and bought a 47 in-line six.
It is the engine, and driveline but no rear end. There is a torque tube.
I bought it basically for the drive line and I couldn't turn it down.
My question, the bell housing is cast, Will the bell housing, Flywheel, clutch, and tranny work with an H series in-line six?
The transmission is a three speed Side loader
The trans will only work in a Ford that has Torque tube driveline, nothing else. Don't know about the BH. The clutch will undoubtedly work, but I can't say if the G flywheel is the same as an H.
Yes. Mostly when it comes time to change the clutch or do tranny work, you have to remove the rear axle. Mostly it's a matter of having a completely different rear suspension and frame. Parts are expensive for them, too.
I assume the driveline and engine are out of a car? You can change the trans to be like our trucks' (open driveline) by changing the main shaft and rear bearing retainer.
yessir, it's just engine and drive line
This picture seems to match
Is there a thin plate that bolts onto the back of the bellhousing, between that and the trans? What closes the hole over the starter drive? I think the G bellhousing differs from the H in that respect.
the blue plate is for the '49, I think it requires a stamped steel bellhousing.
the '47 bellhousing is now mounted on the '49 engine.
the '47 trans has a cast in cover that closes the back of the bellhousing.
I keep hitting those green bars to give attaboys
nothing happens?
Nothing should. If you click on the scale icon just above the green bars on the member's message you wish to acknowledge a dialog box will appear allowing you to add to their reputation. Thanks for asking.
