Misfire Confusion
Old 05-24-2017, 09:12 AM
dwpeugh's Avatar
dwpeugh
dwpeugh is offline
Misfire Confusion
I have a 2002 Ford F-150 with a 5.4 Triton. 212,xxx miles. I replaced the cops and the plugs about 6 months ago. I was pulling a trailer up hill last week and the engine was under a load doing about 3000rpm. It began to misfire and give me a flashing mil. However, before I went very far the engine began to run fine. It happened 3-4 different times. Hoewever, there is no code recorded. I've driven the truck nearly 100 miles with no problems, but I'm going to be pulling that trailer uphill again next week. Any suggestions?
Old 05-24-2017, 09:20 AM
alloro's Avatar
alloro
alloro is online now
Received 4,199 Likes on 2,434 Posts
Fuel pressure could be low due to a worn fuel pump. Low fuel pressure is most notable under a load such as when accelerating, hill climbing, or towing.
Old 05-24-2017, 10:51 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
A flashing CEL tells you that fuel was being passed through to possibly melt the cats in that bank or banks from lack of ignition.
So lack of fuel would not be the problem.
Under load at 3000 rpm and outright misfire that apparently is intermittent.
If the misfire clears long enough the code and CEL would be cancelled.
A way to find which cylinder was the cause is to look at mode 6, test 53 witt a Scanner.
At that location is the misfire record for all 8 cylinders.
This memory does not have an ability to set a code and is not cleared any way but with a power down of the PCM.
One or more should have high counts as the suspect.
It could be the coil, the boot, the connector a plug or even a Cat already causing blockage along with the cylinder misfire.
After all at 3000 on a hill under load, there is less air flowing in the engine bay do to the lower road speed and higher heat produced by the engine.
Good luck.
Old 05-24-2017, 12:37 PM
pdqford's Avatar
pdqford
pdqford is offline
So lack of fuel would not be the problem..
My first guess would be along the lines of alloro's.
A flashing CEL indicates a Class A misfire. PCM doesn't know if it's from a secondary ignition break down or from a lack of fuel or from lack of compression.
It just picks up on rotational delays.
Has the fuel filter ever been changed?
Was the fuel level low when going up this hill?
Is it the original fuel pump?
Why were the COPs and plugs changed 6 months ago.
Might want to tape a fuel pressure gauge to the windshield to check pressure under load.
Otherwise, follow bluegrass's lead for identifying which cylinder is misfiring.
Old 05-24-2017, 01:33 PM
dwpeugh's Avatar
dwpeugh
dwpeugh is offline
The fuel filter was changed about a year ago, but the fuel pump has never been changed. There was probably 3/4 of a tank of fuel at the time of the misfires.
The COPs were changed because I had two go bad inside of 6 weeks and since they all had more than 200k on them I figured it was time to change them. I changed them all at the same time. While I was doing it I changed all the plugs.
I have a scanner but I don't think it does mode 6. I'll chase this with someone who has one. Thanks for the input.
Old 05-24-2017, 08:17 PM
dwpeugh's Avatar
dwpeugh
dwpeugh is offline
Does anyone know where I will find someone who will run a mode 6 scan on my truck without charging me and arm and a leg to do it? I have tried a couple of places but none of them have a scanner capable of running that test. I have a great scanner that I love, but it will not do a mode 6 detailed scan for misfire data.
Old 05-24-2017, 10:54 PM
Bluegrass 7
Not that this will help you much but on page 9 of the OBDII overview, third paragraph under misfire algorithm describes the conditions that will cause the CEL to flash.
Its a loss of ignition not fuel the first time around.
There is a condition that will shut off the injector if the issue is detected a second time to try and prevent melting the cat if it is not already melted by repeatedly driving the truck with the fault..
I have long ago had experience with this kind of fault.
Finding a source with a Scanner to look at this misfire is likely more about not knowing how because they are not competent to go that far in diagnostics.
Good luck.
Old 05-25-2017, 05:55 AM
96f150's Avatar
96f150
96f150 is offline
...Great Question....Who make a scanner that has mode 6 ability, thats reasonably priced?
Old 05-25-2017, 07:43 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
https://play.google.com/store/apps/d...l.torque&hl=en
https://torque-bhp.com/wiki/Bluetooth_Adapters
Kala Lineberger
07-20-2018 08:26 AM
revitup
1983 - 2012 Ranger & B-Series
08-23-2017 01:14 PM
arod79sae
1997 - 2003 F150
06-10-2013 11:49 AM
H_E_R_N
1997 - 2003 F150
18
03-15-2004 02:20 PM
H_E_R_N
03-02-2004 10:33 AM
Quick Reply: Misfire Confusion
