Thinking about putting 35's on my stock 18 inch wheels. I know that since the rim is 9" wide a 12.5 tire is not ideal.
at discount tire they have 35/11.5/18 nitto trail grappler m/t tires for $328.
if anyone has some pics I would appreciate it. Haven't been able to find much, and deciding on what to get has Been driving me crazy. I know I need something bigger. Truck wheels look so small right now
Stock, no rubbing or any clearance issues. You should probably go with an 11.5 to be within manf. Specs, but I've never had an issue with 35s on 8.5in rims.
I had 295/75R18s on my Tundra, which is like a 34.5x11 and change. It's noticably thinner, but not bad.
I ran 35x12.5 BFG KO2's on my 2016 truck with stock 18" wheels. The tire shop cautioned me about the width, saying the Ford rim was slightly narrower than the recommendation...but if I was OK with the risks, than they would do it.
I had no issues whatsoever, and my truck was not lifted or leveled. 100% stock. I can post pics if you like, but it was a 2016.
i ran 12.50's on 7.5 wheels on 150's a few sets with no issue, i wouldnt worry just set your empty pressure with chalk to get the best wear out of them
Nitto ridge grappler 35X11.5R20. And the factory wheel is 20X8. At least the ones I've seen are.
ETA: I think 295X65R20 is the perfect size for the factory 8" wheel. A little taller,a little wider, has a better tow rating and is lighter. What I should have done myself.
