15 DRW Wheel Width
Old 05-22-2017, 02:47 PM
Superduty450's Avatar
Superduty450
Superduty450 is offline
15 DRW Wheel Width
Does anyone know what the wheel width is on the 15 dually with 17" diameter wheels?
Old 05-22-2017, 08:33 PM
bobv60's Avatar
bobv60
bobv60 is offline
Should say on your door jamb sticker. My 2011 F450 is 17x6.5 wheels
Old 05-22-2017, 09:22 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
6.5" wide for 2011-2016
Old 05-23-2017, 08:32 AM
Superduty450
Thanks for the info, getting ready for tires, just seeing how wide I can go on these rims. Thinking Yokohama AT G015 265/70/17.
Old 05-24-2017, 05:43 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
I am running BFG TA-KO2 34*10.5/17, no spacers. You loose a smidge capacity.
ZooDad
Old 05-24-2017, 07:01 PM
Superduty450
ZooDad
What do you tow? Weight?
Old 05-24-2017, 07:12 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
Weekend Warrior LE3505 Toy Hauler. just under 18k loaded and about 4000 on the pin.
3085# load rating per tire
Old 05-24-2017, 08:58 PM
Superduty450
What gears are you running? I have 3:73 and if I go that tall of tire then they will be 3:55s my 5er is 19K.
Old 05-24-2017, 10:01 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
I have 3.73 also. I have a spreadsheet I did a while back that showed rpm to tie size to gear ratio. I'll see if I can find it.
I never felt the difference between the stock and my new ones.
Old 05-25-2017, 08:33 AM
Superduty450
I am not worried about the speedo since mine is off by 3 mph at 65, if I go with 33" tires the increase tire size will bring it right on, I am more worried about the gear change. I may go with the Toyo Open Country 255/80/17.
Old 05-25-2017, 10:52 AM
ZooDad's Avatar
ZooDad
ZooDad is offline
SuperDuty450
Here is the sheet.
Take a look at the RPM values in the different gears. This will address your power (gear) concerns.
You will see my reference on the 34's. This is actual size based on calculation obtained from driving.
The remaining tire sizes are based from an online calculator.
Hope this helps.
Keith
Old 05-25-2017, 02:50 PM
Superduty450
Thanks for the info, very helpful. I see one error in the sheet and that's the 245/75/17 Dually showing the tire at 28 when the General Grabber HTS website shows 31.5 which came on my truck
Old 05-25-2017, 06:22 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
Agreed, and I did not say above. The size for stock was based on actual rpm calculations in the truck. So that is what the actual" rolling" size is.
Keith
Old 05-25-2017, 07:42 PM
Ferguson65's Avatar
Ferguson65
Ferguson65 is offline
That's the first I've seen of an LT255/80R17 in an all terrain. I'll be making a mental note of that!
Old 05-26-2017, 10:14 PM
bobv60's Avatar
bobv60
bobv60 is offline
I was just looking the other day and I did not see Toyo making that size. I could only find BFG and Cooper making them.
Quick Reply: 15 DRW Wheel Width
