Part name or schematic for electrical under dash
I had discussed the error codes and the batteries being hooked up in reverse on my truck with someone.
They came and looked at my truck as they figured they knew what was wrong. They reached/looked up under the dash and the part was expanded and the back side blown out. (their terms)
Apparently this part is famous for going out on the 97's, water can leak from the windshield down in behind the dash and cause damage to this part. Anyway - I didn't write down what this part was called as they were going to pick one up for me, I have yet to hear if they have and its been over a week and they are not answering nor called me back that they have it, they were getting it from a wholesaler so I am presuming its a 300 or a bit more part.
So all I can say is the part under the dash most/all of the electrical can run through it and its a common part that can go out.
Does anyone have a schematic or can you tell me what the part is?
Sorry I don't have much more info.
Thanks
Thanks
He was looking up under the drivers side. If I knew exactly what he was looking at I could take a picture. That's the unfortunate thing all I caught was that its a part that when the windshield leaks and the water runs down and behind the dash its a component that get wet and breaks. He also said its the one that the majority of the electric goes through so like my radio that is not working could be caused by this component not working. Sorry I have not been able to get in touch with him since he said he would get the part so I don't have the specific part name.
The pcm should be opened and checked for moisture issues.
E brake bracket doesn't appear to be loose. He said the part that majority of electronic goes through, its notorious to going out after getting wet from windshield leaking which my truck does, he took down the last 5 numbers of my vin and A/ to be able to get the part. . I reached out to him yet again today and get no answer so apparently I have lost the money I paid for the part as well as the part.
My dome light still comes on I have not tried to start it as the keys were pulled. Will I wreck more thigs if I start and drive it to town?
I did find this today small screw/bolt and he may have taken it out but I never asked where from under the dash.
