VIN Problem - F350 King Ranch
Old 04-28-2017, 12:34 AM
gbison's Avatar
gbison
gbison is offline
- This is a re-post from the Super Duty forum, thanks Preston -
Evening folks,
Im working on buying a truck and Im hung up on this one diesel truck that I want bad, could be the deal of a life time but there is a problem....
So, I drove 2 hours to pickup a 2007 F350 King Ranch FX4 Crew Cab to keep for the next 48hrs and to test before I make the purchase. The stealership has been great about it. The truck itself on the outside looks like new, immaculate really. The inside, looks great, seats need conditioning but I expected that, everything else seems good. The truck itself runs like a freaking top, probably one of, if not the most powerful 6.0 I have tested!
Now, the problem................ the VIN in the ECM and the VIN on the truck dont match . I have an Autel MaxiDiag diagnostics scanner and I pulled out all the codes, vehicle information and performed 5 different tests on the truck including the injector tests- truck passed with flying colors except two problems, glow plug circuit on cylinder 1 and vin mismatch.
The glow plug circuit cylinder one didnt concern me half as much as the vin mismatch. What does this mean? Should I just forget my dream of owning this truck and run it back as fast as I can? I am suppose to be at TSI Innovations in Johnson City , TN in the morning at 11AM for a full on IDS based diagnostic and overall analysis of the truck - should I just forget it and take it back?
Any help folks would be extremely appreciated!!!
Thanks
Bryan
Old 04-28-2017, 01:19 AM
silverbullet6oh's Avatar
silverbullet6oh
silverbullet6oh is offline
Bison,
I sent you my Ph #.
Call me tomorrow.
- Preston
Old 04-28-2017, 02:04 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
So then the ECM was flashed or replaced... not a big deal.
Does it prevent it from being titled or registered? You could have Ford flash it if that's the concern.
Old 04-28-2017, 02:12 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Maybe have a Ford dealer run an Oasis report on both for kicks!
Old 04-28-2017, 02:45 PM
silverbullet6oh
Yeah, at least it would sound like a valid reason.
Cause by God if you don't have a good enough reason for them, they will tell you "no" on the report.
Old 04-28-2017, 03:27 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Actually, Sean may be able to flash it with his IDS.
Old 04-28-2017, 06:45 PM
DarkStarMedia's Avatar
DarkStarMedia
DarkStarMedia is offline
I seem to remember that forscan can change the VIN in modules... But I could be wrong
Richard
radio flyer
2017+ Super Duty
11-17-2017 08:02 PM
gbison
1999 to 2016 Super Duty
13
04-29-2017 09:27 AM
DL222
2017+ Super Duty
08-26-2016 07:38 AM
chadjones99
02-16-2015 05:28 AM
CruisnPhantom
01-24-2004 08:31 AM
Quick Reply: VIN Problem - F350 King Ranch
