Intermittent A/C
I have a 2004 F250 4x4 with 204,000.... runs great! But last year, I noticed the A/C would work fine to begin with, but after running down the road a bit, it would cut off and I would have to turn it off,,, let it "rest" a bit,,, then it may or may not come back on,,, now I am a electrician by trade, and I figure it is a bad switch somewhere,,, but a intermittent problem is heck to find sometimes!!! I replaced the low pressure switch in the accumulator, then I was thinking the little wiring plug might be bad,,, so I replaced that,,,, but it's still doing it.
I was going for the relay next, but I'm not sure which one it is,,, and can't seem to find a wiring diagram for the system.
Sorry for the long post but I'm stumped on which way to go,,,,
Oh yes,,, I grew up in the A/C electrical business,,, so yes,,, its full of 134a and will freeze you out--- when it works!!
Per4mance got you I was too slow
Apparently that's not the case for you. I'd agree if it's freezing then your orifice is partly blocked or the system is over charged. If the high side gets too high the system will shut itself off and that might be what you're seeing.
Now,,, the clutch doesn't look worn out,,, so I would like to try to pull a shim out of it to see if that might get me by for a bit, or when I get it out, I may just replace it,,, depends on how it looks
So question,,, been a while since I have done this,,,, will I loose the r134a completely,,,, and do I need a clutch puller,,, if there is a procedure here I would appreciate the advice
Thanks in advance
First measure the gap and write in down for a base line. Later you could use a mic or calipers to get the correct shims needed for adjustment.
Remove the center bolt by either holding the out clutch disk or with engine off actuate the clutch and loosen the center bolt.
There should be spare washers (shims) on the bolt.
Remove the outer clutch.
At the bottom of the clutch disk shaft there should be shims. Removing what is needed to achieve the recommendation. There is a shim kit available if needed.
I found a video similiar to help visualize.
But seriously, don't screw up your chance to check the air gap while it was actually having problems by not doing ^^^^ all that stuff from a post up first.
