Thanks for the replies,
the owners manual is gone.
the existing is a side mount, infront of the axle.
IF i remember correctly the '83 F100 only had one bed length and it's the longer of the 'standard' lengths. I'll measure it tonight.
And, as I type that I could probably figure the correct tank by measuring it.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
Note: 1983/84 F100/150 with 117" wheelbase (6 1/2' short bed) uses a different fuel tank.
Sorry I was a bit vague there, I meant that I thought that for the regular cab there was only one bed length other than the step side.
Mine is a standard cab so most likely the 8' bed but I'll measure tonight.
Sorry I was a bit vague there, I meant that I thought that for the regular cab there was only one bed length other than the Flareside (a step side is a Chevrolet).
Mine is a standard (Regular) cab so most likely the 8' bed but I'll measure tonight.
1980/83 F100's were only available as Regular Cabs, no Super Cabs were available.
Two wheelbases were available: 117" Flareside & Styleside 6 1/2' short beds, 133" Styleside 8' long bed.
8' Styleside bed (not a bed with steps ) so Spectra F6A should be it.
I sincerely appreciate the help!
John
Actually, I have a 1982 F100 styleside with an 8' bed and the Spectra F14A was what fit mine. It's installed and worked perfectly. You can get it at Advance Auto Parts, and if you order it online and ship it to a local store, you can use the code 'TRT30' to get 30% off! It's the 16 gallon side mount version.
A 16-gallon tank will fit a long bed truck. But so will (well, so should) a 19-gallon tank. But a 19-gallon tank won't fit a short bed truck.
True as I tried to install the spare 19 gal tank on my Flare Side (short bed) truck and was a no go so the 16 went back on.
Originally Posted by IppoJ
that's a helluva deal, I already ordered the 19g/straps/pickup just so it should be a drop in (drop up?) install.
Thanks for the tip!
John
I think it best you did go with the 19 that the truck came with.
I wanted to go with the 19 for the added miles as my truck only had the 1 16 gal tank.
I said "only" as I am adding the 19 gal rear tank from my parts truck. The Flare Side never came with duel tanks so it will be a custom install.
Dave ----
I know.. I was just mentioning what I had bought that fit. I opted for the 16 gallon as my truck is just a weekend occasional trip to Lowes or joy riding.
Mine will be about the same may be 60 miles round trip to work just did not want to have to fill up each way is all
I would have liked to install that 19 gal but the cab got in the way
Dave ----
