Fuel Tank Size
Old May 22, 2009 | 07:36 PM
normahp's Avatar
normahp
Fuel Tank Size
I just bought a 2000 F250 7.3L Diesel, can anyone tell me what the average take size might be?
Old May 22, 2009 | 07:39 PM
liftedgrocerygetter's Avatar
liftedgrocerygetter
Depends on what size bed you have. If its a short bed you have a 29 gal tank. If it is a long bed you have a 38 gallon tank.
Welcome to FTE!!
Old May 22, 2009 | 08:13 PM
Izzy351's Avatar
Izzy351
To add to what Cris said, they hold quite a bit more than the number in the owner's manual. When I dropped my tank to do the mods, I had it pretty much empty, and when I filled it to the neck, it took right around 34.5 gallons. That's from dead-empty (minus the pint or so sloshing around in the bottom that the pump couldn't get out). The 38 holds something like 42 or 43 gallons (someone check me there). Oh, and the Excursions have a 44 gallon tank, that must hold close to 50...
EDIT: And I have put in over 31 before. There was a bit of pucker factor when I made that run, but now I know there was about three more gallons in there. LOL
Old May 22, 2009 | 10:32 PM
Excursion4X4's Avatar
Excursion4X4
40 or so is about all I can get in the tank when I really let it get low.
Old May 22, 2009 | 10:40 PM
superduty4x4's Avatar
superduty4x4
Mine holds over 50... but it ain't stock
Old May 23, 2009 | 03:21 AM
Visseroth's Avatar
Visseroth
Mine is a 38 but if you're a weird-o like SuperDuty4X4 you have some crazy stainless steel aftermarket, no one knows where it came from and I want one, 50g tank that will take you 2/3's of the way across the country!!!
I want one!!!!!!
Edit: Oh, I forgot to mention...... Early 99 F250 Super Duty, 7.3L extended cab (AKA supercab) long box 4X4
