F350 Tire Pressures
F350 Tire Pressures
What kind of tire pressures are members running on their F350s SRW when empty ?? The door sticker indicates 60 lbs front, 80 lbs rear for tire pressures, and that is what my dealer had my tires pumped to when I picked up the truck. But considering that the front is much heavier than the back when unloaded, that just makes sense that you don't need that kind of pressure in the back tires when running empty. I tried 60 lbs all of the way around, and the truck seemed to handle better than with 80 lbs in the rear tires. But I had 1 rear tire that showed "low tire pressure" on the dash screen.
What say y'all ??
What say y'all ??
