Leveling kit for a F350 CC LB 4x4
Old 01-10-2017, 11:51 AM
paintubturner's Avatar
paintubturner
paintubturner is offline
What do you guys recommend for a leveling kit for my 97 f350 CC LB 4x4?? Thanks
Old 01-10-2017, 12:27 PM
ved0303's Avatar
ved0303
ved0303 is offline
depends how much you want to spend. add-a-leaf kits are relatively cheap but you can do a reverse shackle kit, such as the one from PMF, which will level the truck and make it ride ten times smoother also.
Old 01-10-2017, 08:47 PM
97-psd's Avatar
97-psd
97-psd is offline
This is what I will be using. The add a leafs do level it up but ride quality is terrible
92-97 Ford F-250/350 2" 4x4 Front Shackle Reversal ? Sky Manufacturing
The shackle reversal is the way to go
Old 05-23-2017, 02:27 PM
paintubturner
Anymore suggestions about leveling the truck?
Old 05-23-2017, 02:46 PM
paintubturner
can these be used to level the front end???
Ford F-250/350 Fabricated Lift Blocks
Old 05-23-2017, 03:10 PM
fordman67's Avatar
fordman67
fordman67 is offline
Um no. Check zero rate spring.
Old 05-23-2017, 03:14 PM
paintubturner
I'm not sure what that means. Sorry. My springs are zero rate?
Old 05-23-2017, 03:48 PM
paintubturner
I figured it out
Old 05-24-2017, 11:54 AM
paintubturner
Do these trucks take a 1.5 inch or 2 inch kit to level the front with the rear?
Old 05-25-2017, 08:33 AM
fordman67's Avatar
fordman67
Have you checked your front leaf/shackle bushings? Mine with new bushings and very sagged 300k+ springs was in the 1.5 range. I would suggest find some flat ground and measure at the rocker and see what your truck needs.
Old 05-25-2017, 10:46 PM
bballcrf's Avatar
bballcrf
bballcrf is offline
do the 2.5 kit and the truck will be level if rear is stock with the 4 inch block, i did the 3.5, rear is stock, and im 1 inch high in the front, good thing i did because my 35's rub if i turn to sharp.
Old 05-26-2017, 07:37 AM
jimzpsd's Avatar
jimzpsd
jimzpsd is offline
If your not concerned with the height, you can lower the rear with shorter blocks.
Old 05-26-2017, 09:56 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
I've got the stock 250 2" blocks from before I lifted my truck... Pm me if interested
hanlinhound
07-19-2009 09:53 PM
throwdown
18
03-06-2009 11:08 AM
lombardo96
Offroad & 4x4
01-30-2006 04:44 PM
redneckf350
Offroad & 4x4
10-01-2005 11:08 PM
Quick Reply: Leveling kit for a F350 CC LB 4x4
