9 inch destruction! It went bang, it's FUBAR!
on
You mean kinda like how the azz end of your rig waved goodbye to me yesterday after work? I assume this means you haven't had a chance to get that latest governor in your AOD.
on
Boys and girls, can anyone tell me what this is?
That's right! That is a ring gear bolt! It lives with all the other ring gear bolts inside the gear case.
However, this family of bolts decided to be mischievous and cause all sorts of trouble...
Sooooo, this case is ruined. I have another loose axle I can rob the case from, or maybe i will buy a new case.
The gears look to be ok, although with the ring gear loose I wonder if it was flopping around and warped?
I don't understand why or how they came out. When I assembled all this back in December I Torqued them properly and used loctite on them.
They look a little peened on the tops of the threads. Should be a nice sharp peak. Did you tumble clean them? Since they are all coming out there seems to be an imbalance in the system. If they were already peened like that when you built it then you did not have face to face contact on the threads. It would have been edge (peen tangent) to face which is much less friction than a face to face to face. Long story short: it will torque correctly but does not have the same holding force. A little bit of vibration would be enough to eventually back them out.
