Stock Ford Radiator Sizes?
Old Feb 3, 2012 | 08:38 AM
Rick_Fury's Avatar
Rick_Fury
How many stock radiators did Ford offer for a 1992 - 1996 F150 with a 302/AOD transmission? I have a 1992 model with A/C, and my original radiator is in need of replacement. I have noticed in the junkyards that some are quite a bit thicker than mine. I do not want to buy a junkyard radiator.
The one I have now is a very thin radiator no more than about 1" thick. I have seen others with the same engine combination that had radiators double that size. I am assuming more cores for better cooling? What determined which radiator your truck received? I would like the thicker radiator to replace the thinner one I have now. Can someone tell me what to tell the Ford parts counter so that I receive the bigger radiator? And will my stock fan shroud work with the thicker radiator?
Thanks!
Old Feb 3, 2012 | 08:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rick_Fury
How many stock radiators did Ford offer for a 1992 - 1996 F150 with a 302/AOD transmission? I have a 1992 model with A/C.
1990/96 F150 302 AOD
1) Without A/C .. Standard Cooling.
2) Without A/C .. Super Cooling.
3) With A/C .. Standard Cooling.
4) With A/C .. Super Cooling.
And this is just for these specific trucks. The list of radiators goes on and on.
1990/96 F150: 300 or 351W with AOD, with C6, with M/T. Without this, without that...with this, with that.
Old Feb 3, 2012 | 09:34 AM
Rick_Fury's Avatar
Rick_Fury
Wow. That is a lot of options.
I would like the 1990/96 F150 302 AOD with option 4) With A/C .. Super Cooling.
Will you provide a part number for this, NumberDummy? And is this still avaialble from Ford? Thanks!
Old Feb 3, 2012 | 10:19 AM
hivoltj's Avatar
hivoltj
For your particular truck, 2 different options.
a 1" thick core, which was standard cooling
a 2-1/4" thick core, which was super cooling
A/C or not does not matter
The fan shrouds are different though, so if you upgrade to the thicker radiator, you'll need to grab the shroud also, or drill some holes in yours. If you buy a junk yard radiator, make sure they warranty it for thirty days and test it before you install it. I work at a radiator shop, and 8 out of 10 times when someone brings in a junkyard radiator it's bad!
Old Feb 3, 2012 | 10:49 AM
NumberDummy
Originally Posted by hivoltj
For your particular truck, 2 different options. A/C or not does not matter.
Uh huh...
From the 1990/2001 Ford Light Truck Parts Catalog / 1990/96 F150 302 AOD with A/C
F3TZ-8005-A (replaced F2TZ-8005-R) .. Super Cooling Radiator-Use with A/C / Obsolete
Last MSRP: $411.46 // Dealer net cost: $267.45.
THOMASSEN FORD in Charles Town WV has ONE = 304-725-7031.
No other Ford Dealer, no obsolete parts vendor has any. No one has F2TZ-8005-R.
F2TZ-8005-DA (replaced F2TZ-8005-F) .. Super Cooling Radiator-Use without A/C.
E5TZ-8146-J (replaced E2TZ-8146-D) .. Fan Shroud-Use with Super Cooling Radiator / Obsolete
Last MSRP: $207.20 // Dealer net cost: $124.32.
20 available NOS from FoMoCo Dealers, 1 available from an obsolete parts vendor.
Old Feb 3, 2012 | 11:30 AM
Rick_Fury's Avatar
Rick_Fury
Since the radiator I need is not available from Ford anymore, can someone recommend a good quality aftermarket "super cooling" radiator?
NumberDummy, I can't imagine that the later 1993+ models that had an 4R70W automatic transmission used a different radiator than the AOD. Are those still available from Ford?
Old Feb 3, 2012 | 11:33 AM
NumberDummy
Just have your original radiator recored by a radiator shop. If you want a thicker core, they can do that too.
I had a 2 row from a 1965 F100 352 recored. When I got it back, it was a 4 row, cuz that's what I requested.
Remove the cap, take a look-see into the top tank to see how many rows your radaitor has, then go from there.
Old Feb 3, 2012 | 04:47 PM
hivoltj's Avatar
hivoltj
Yeah, I know what the Ford catalog shows, I'm talking about what actually fits/interchanges
And you don't re-core plastic/aluminum radiators, you rodout and repair them, or get a new one, which is usually the same $ or cheaper.
Old Feb 7, 2012 | 10:04 AM
Rick_Fury's Avatar
Rick_Fury
Thanks, hivoltj. To use my existing fan shroud, would I have to drill the holes in the fan shroud to fit the larger radiator or the radiator itself?
Old Feb 7, 2012 | 10:12 AM
hivoltj's Avatar
hivoltj
Sorry I didn't specify, it's been a while, but IIRC you have to drill new holes in the top piece of channel running across the radiator and possibly move the little clips at the bottom over.
Old Today | 01:46 AM
rocketroy's Avatar
rocketroy
1990 f150 302 manual box 4x4
I had a thin radiator and I switched to the thicker super cooling one.
i bought it from pick and pull kelowna bc. For $60 I think.
the truck it came from was there because it was rusted out I believe.
i got the the thicker radiator and shroud.
going up the coquihalla, with a load in the bed on a sunny day
the difference in cooling is night and day.
i know that much.
Old Today | 08:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
14 year old thread resurrection
Originally Posted by rocketroy
1990 f150 302 manual box 4x4…
i know that much.
I basically had the same truck. There was a problem with the cooling system which is why you replaced the radiator. I towed with my truck a few times and hauled firewood several times at highway speeds. The single row radiator is plenty to keep the engine from overheating.
Old Today | 11:37 AM
rocketroy's Avatar
rocketroy
then we’re going to have to agree to disagree,
it had 2 full tanks of gas, 5 people inside.
the bed was loaded with way more fire wood that the truck should ever carry.
then it was pulling the 2000lb boat
on that day it was almost 31c
the manual transmission was pulling up the hill in second gear
the coquihalla from hope to the summit is 31 miles.
stupid thing to do really.
we pulled over half way to let it idle for 10 minutes and then it climbed the second half.
but I can assure of this, thst truck never over heats.
but that day it absolutely did need a rest.
i didn’t even know there was a red engine light.
Old Today | 01:16 PM
My4Fordtrucks
Because there was something wrong with the cooling system that didn’t show up until that day.
Well…it’s always been there to left you know the gauge was in a danger area. It also comes on if oil pressure is too low.
94MustangGT
Oct 23, 2017 07:40 PM
Whiplaunch
Aug 19, 2014 11:54 AM
Dads79
Mar 7, 2007 01:28 PM
JoeVB
Dec 24, 2005 07:28 PM
FILDO
Mar 25, 2002 06:51 PM
