Mysteriously gone ABS module
I have a 2005 F250 6.0l. I have no speedo and the ABS light is on. It was intermittent at first. It would go on and off if I hit a bump or braked quickly, but now for the last month the light has been on constantly.
I have tried the following to no avail:
1. check the harness to the VSS (rear ABS senor on the pumpkin)
2. replaced the VSS on the rear
3. check the lines from the vss for resistance and open short (and short to ground)
4. checked the HS-can network (pins 14 and 6 in the DLC to the respective HS-can + and - on the module) both have less than 5 ohms (about 3 ohms found) and no short.
5. checked the resistance of the network itself across pin 4-16 and found 60 ohms.
6. ran scans with OBD fusion for ABS (no abs found)
7. ran scans with forscan with laptop, does not detect ABS unit neither new or old module. note the TBC and IC both throw codes about not detecting the ABS.
8. check HS-can on the PCM as well as VSS wire from abs to pcm, no shorts or resistance.
9. check the number 11 fuse, (good) checked ALL fuses, only bad fuse found was trailer light number 20 engine bay. issue was a wire at the tailer connector was t-taped and not sealed leading to a short to frame.
10. checked the connector to the ABS module for power on both constant power pins, for open ground on both grounds, and power on run, all with in spec.
I've been diagnosing this for the last week, I am running out of things I can think of to check.
from the wire diagrams I have, there is no brake pedal sensor wire connecting to the ABS module. just the following connections
-(3) pair of sensor leads to the abs wheel speed sensors (hall effect)
-2 chassis ground
-2 constant power
-power on run
-VSS signal (grey/black) (the abs creates the VSS signal based on the ABS speed sensors)
-HS-CAN +
-HS-CAN -
the VSS wire I have checked for open fault and power fault (grey/black)
where should I be looking for the brake pedal sensor to connect to? PCM?
-2 chassis ground
-2 constant power
-power on run
-HS-CAN +
-HS-CAN -
-2 chassis ground
-2 constant power
-power on run
-HS-CAN +
-HS-CAN -
-2 chassis ground
-2 constant power
-power on run
-HS-CAN +
-HS-CAN -
This might help:
https://www.ford-trucks.com/forums/1...elp-of-ae.html
Not getting communication at all? It seems that you did your homework and checked some things out. I'd have to double check. It seems that the ABS module may be faulty but you said you tried a couple of others and still no talking to the PCM. So I'm wondering if it's on the PCM side?
(Thinkin out loud here^)
It's certainly possible. I don't have another pcm to try unfortunately. The way I understand the trucks computer architecture: there are the two busses (ms-can and HS-can) connect directly to the dlc (obd2) port. And each module connects to those busses in parallel. So if I am reading a abs fault from the tbc module and the IC module as well. then I'm not sure if the pcm would be the problem. I would disconnect the pcm to diagnosis whether it is adding superfluous noise into the bus but it has one of the two terminating 60ohm resistors (the other one being the ic) if I remove the network would become unstable as the messages would propagate endlessly (i believe)
