1963 Ranchero w/ a engine swap
heres a fun little project.
63 MANchero
chassis: 89 F350 CCLB 4WD slightly trimmed.
4" spring lift
4:10's
mock up tires are 33-ish
7.3 IDI N/A block.
turbos.... TBD.
I would like to see what it takes to grenade this block
zf5
started rebuilding the floor the unibody was too wasted to repair.
63 MANchero
4" spring lift
4:10's
7.3 IDI N/A block.
turbos.... TBD.
zf5
hope to have it running by the end of the month.
14 gauge sheet metal will be here Tuesday, by then I should have the bracing for the new floor done.
got a lightning seat to install
fuel lines, brake lines, wiring harness all on order
itll go pretty smooth, don't expect any major hiccups minus the innercooler.
but well cross that road when we come to it.
also have a RSK stuff on order.
Received 3,307 Likes
those manifolds will not be used.
ill be building a set of headers.
some of that tubing may be cut out after I start layin down the 14 gauge.
I.E. the cross over on the trans, I think im gonna radius it up a bit.
this is all there just to get a basic outline of the floor.
the drivers side is golden, but the passenger side would be pretty tight, but still can be done.
if you think that's tight, try doing headers on a 427 in a 65 falcon lol, THAT was TIGHT.
the nature of having an IDI in a 63 ranchero
the engine is in the proper place for the frame.
will have a removeable dog house on the inside.
also wouldn't be hard to pop the cab bolts and lift it.
not much to report today. cleaned up, welded some nuts into the cab mounts, and plated em in to keep debris out.
the sheet metal for the floor I decided to send to my buddy to brake the ends so it will be a cleaner install, but he couldn't do it today, I had to leave it with him.
I really need a 6' brake, I was 6" too long for the 4 footer.
its ok tho, the next couple of days im hopin back on the super duty, for a 4" lift and axle swap.
