Sponsored by: Halo Lifts
Oh no my aluminum is rusting badly
Old 12-18-2016, 08:37 PM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
No not really.
And aluminum doesn't rust.
I love my 2016 f150s not a single problem.
But made the paranoid few look I am sure.
Merry Christmas and go hug your truck now for being so darn awesome to you☺☺☺
Old 12-18-2016, 09:49 PM
j.grif's Avatar
j.grif
j.grif is offline
No it does not rust, it just turns to white powder and developers cracks, moisture is its enemy, calcium chloride and other corrosives used on the roadways are its enemy, if only we could operate off grass runways, we would have it made! Merry Christmas back at you!
Old 12-18-2016, 11:22 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
I wonder if a sacraficial zinc anaode could be attached to major body parts to draw the corrosion away from the body and to the anaode. It works for outboard boat motors.
Old 12-18-2016, 11:35 PM
j.grif's Avatar
j.grif
j.grif is offline
Aluminum boats have those sacrificial anodes as well, never seen those on heavy trucks or trailers though, unless you consider brake chambers sacrificial!
Old 12-18-2016, 11:57 PM
Torky2's Avatar
Torky2
Torky2 is offline
Bare Aluminum rapidly forms a passivating layer of Aluminum Oxide. Unlike Ferric Oxide (our ol' buddy, rust), Aluminum Oxide protects the underlying Aluminum. Unless it's oxide is removed and prevented form re-forming, then it goes quickly!
And in design, there is the whole galvanic action issue. There were full-size Fords and Mercs some years that had aluminum rear bumpers, the big ones. They had two isolation pads that fit in between the mounting areas of the bumper, and the two steel frame-ends which were the bumper mounts. They were, or were like, lead sheets. They stuck out way beyond the joint on all 4 sides.
Old 12-19-2016, 12:38 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Maybe you mean sodium chloride (AKA salt)?
Old 12-19-2016, 12:57 AM
j.grif's Avatar
j.grif
j.grif is offline
, no, we have stuff in Michigan that is even more corrosive than sodium chloride, we have magnesium chloride and as mentioned calcium chloride, in addition to various brine solutions.
Old 12-19-2016, 10:30 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Oh wonderful...
Old 12-19-2016, 10:38 AM
Tom's Avatar
Tom
Tom is offline
Lots of Chlorides are used to treat roads, salt is only one of them.
I know the thread was made in jest, but I suspect we're going to see actual posts of corrosion issues at some point. We'll see.
Old 12-19-2016, 12:42 PM
airm4n's Avatar
airm4n
airm4n is offline
Galvanize the truck. Look like crap but no problems.
Old 12-19-2016, 12:53 PM
02FX4Dude's Avatar
02FX4Dude
02FX4Dude is offline
sodium chloride (NaCl), aka salt, dissolves and lowers the freezing point of water, higher concentration = lower freezing point.
calcium chloride(CaCl), aka ice melt, reacts with water and generates a small amount of heat and melts ice and snow.
with a mixture, the CaCl will melt snow and ice,the NaCl will mix with the water and lower the freezing point. I think MgCl can be used the same as CaCl but not sure.
All are corrosive to metals.
Old 12-19-2016, 01:04 PM
David W Jones's Avatar
David W Jones
David W Jones is offline
If the aluminum starts rusting, set it on fire. The rust will stop.....
Old 12-19-2016, 03:09 PM
PupnDuck's Avatar
PupnDuck
PupnDuck is offline
Go find a three or four year old Explorer or Mustang and check out the leading edge of their aluminum hood. Virtually every one I've seen has the paint blistering and peeling in several spots. Apparently the problem is that the hood skin is aluminum but the stiffening ribs are steel. One rock chip on the leading edge and the cancer starts.
Old 12-19-2016, 05:24 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
F150 hoods have been aluminum since '97. Haven't seen any corrosion issues with them in this part of the country.
Old 12-19-2016, 06:04 PM
sky Cowboy's Avatar
sky Cowboy
I have many aluminum bodied Peterbilts, aluminum trailers, aluminum helicopters, aluminum boats, and in harsh BC winters.
Corrosion issues=zero!
Quick Reply: Oh no my aluminum is rusting badly
