How to get the best MPG
Old Jan 24, 2006 | 02:40 PM
JeffreyK's Avatar
JeffreyK
My last truck before buying my PSD was a 2003 Hemi Ram 2 wheel drive that was getting 13mpg, the truck weighed in around 5300 lbs.
My 2005 Crew Cab PSD 4x4 with 33" tires, and a 65hp power programmer mod and is getting 14mpg and that thing is pushing 8000 lbs.
So all relative, the mileage is not that bad considering the size of the vehicle. Although I would not mind saving a few bucks at the pump either.
Old Jan 24, 2006 | 02:47 PM
Vic_Ferrari's Avatar
Vic_Ferrari
Remember this much:
Load (as in calculated engine load) affects fuel mileage more than RPM.
If you've got a datalogger, you can play with RPM/speed/gear selctions with varying loads (as in payload), and watch the calculated engine load change. The lower the calculated engine load, the better your mileage will be.
Quite often, a HIGHER RPM will create a better mileage situation, if it causes a reduction in calculated engine load (very common).
Sometimes when the RPM is too low, the truck is "lugging" and the load (and as a result, fuel consumption) is higher.
In other words, going up that hill with the trailer at 3,000 RPM in 3rd gear will *usually* cause better mileage than going up that same hill at 1800 RPM in 5th gear.....
Old Jan 24, 2006 | 03:22 PM
Wild-Bill's Avatar
Wild-Bill
I've found I always get better milage if I use the cruise control.....even off the freeway and on back roads at fairly low speeds. You can't help but accelerate very slightly as you drive then back off slightly to compensate. The cruise uses just enough fuel to maintain speed within a narrow speed band and not a drop more. Try it. You'll be amazed at the difference.
Old Jan 24, 2006 | 04:14 PM
Vic_Ferrari
Cruise can help a lot if you tip in on the throttle too hard regularly.
Old Jan 24, 2006 | 04:51 PM
WWBeast's Avatar
WWBeast
Ya wouldnt boost be a better indication of how much fuel your using rather than RPMS, since the harder you push down on the throttle the most boost you get. I dunno i always judge it by that. If im goin 2200 RPMS but only using 5psi of boost i usualy get better mileage. Odd thing comin back From Dallas to Austin i was on avg goin 80-85 i mean we were all hauling got the best mileage yet haha 20.3. Couldnt believe it.
alamartina
34
Nov 17, 2013 05:24 PM
tonyk72
Apr 25, 2008 01:27 PM
Hammerhardonit
Ontario Chapter
19
Jan 16, 2008 12:19 PM
tanman722001
North Carolina Chapter
Sep 24, 2006 08:00 PM
Badford
Apr 22, 2003 03:56 PM
