Ownercard Warranty ID Card decoded
I'm curious if any experts could assist me with deciphering the warranty card on my 73 F250 Camper Special. Thanks!
F25HUS05848 UQ 23 F252 4 37J G A |
Is this is the Warranty card in the dealership Folder from the glove compartment ?
F25HUS05848 UQ 23 F252 4 37J G A F25 = F250 2WD H = 390 2V U = Louisville KY Assembly Plant S05848 = 1973 UQ: U = Light Yellow Green / Q = Medium Lime Metallic 23 = ? DSO code? If so: Memphis TN Ford District Sales Office, where original selling dealer ordered the truck from. F252 = F250 2WD Pickup / 7500 lbs. GVWR 4 = ? Could be trans code, but 4 not used except on F500's. 37J: 37 = Dana 60 / 3.54-1 / 5300 lb. Rear Axle Capacity / J = Power Steering G = ? This also could be the trans code - if so = C6 A = ? Could refer to factory installed air conditioning. Look on the Rating Plate, left door face near the latch. Match the codes on the owner card with what you see on the plate...some of those codes make no sense, without knowing what they're for. |
I'm no expert, but here's what I found.
F25 = F250 2WD H = 390 2V U = Louisville KY Assembly Plant S05848 = 1973 UQ: U = Light Yellow Green / Q = Medium Lime Metallic 23 = ? DSO code? If so: Memphis TN Ford District Sales Office, where original selling dealer ordered the truck from. F252 = F250 2WD Pickup / 7500 lbs. GVWR 4 = ? Could be trans code, but 4 not used except on F500's. 37J: 37 = Dana 60 / 3.54-1 / 5300 lb. Rear Axle Capacity / J = Power Steering G = ? This also could be the trans code - if so = C6 A = ? Could refer to factory installed air conditioning. Look on the Rating Plate, left door face near the latch. Match the codes on the owner card with what you see on the plate...some of those codes make no sense, without knowing what they're for. It also has Ranger badges/trim. I'll compare it to the door tag like you suggested. Thanks again. |
I had most of that typed then I realized it might the booklet card so I deleted it
The 4 stands for Styleside pickup I think the A means Conventional pickup Yours is the first card I have seen with that much info on it. I have 3 of them to look at. My 78 is lacking about 4 codes and I bought mine Brand new in 78 |
The 4 stands for Styleside pickup. I think the A means Conventional pickup.
In the car parts catalog: A = A/C, factory installed. |
Bill here are 3 threads about this from way back ;)
https://www.ford-trucks.com/forums/4...nd-papers.html https://www.ford-trucks.com/forums/4...f-150-4x4.html https://www.ford-trucks.com/forums/4...-question.html |
[QUOTE=
UQ: U = Light Yellow Green / Q = Medium Lime Metallic QUOTE] I've done some further research and found that for 1973 U=Limestone Green Poly, and Q=Winter Green. Please anyone correct me if my information is incorrect. |
[QUOTE=pcskies]
UQ: U = Light Yellow Green / Q = Medium Lime Metallic QUOTE I've done some further research and found that for 1973 U=Limestone Green Poly, and Q=Winter Green. Please anyone correct me if my information is incorrect. |
Here's mine
the original and the extended warranty
<a href="http://s262.photobucket.com/albums/ii99/mfix78/?action=view¤t=card.jpg" target="_blank"><img src="http://i262.photobucket.com/albums/ii99/mfix78/card.jpg" border="0" alt="Photobucket"></a> maybe yhis should have its own thread |
That is really cool that the card is in that good of shape.
I never got the extended service plan so I never got one of those cards.
The 77 card is slightly different than the 79 card. I'll have to check my 78 card. |
1973
U = Limestone Green Poly Q = Winter Green |
what is that tag in post 11?, towards the bottom left. the 78 i just bought has one in the glove box, nothing else though
