Ownercard Warranty ID Card decoded
Originally Posted by pcskies
I'm curious if any experts could assist me with deciphering the warranty card on my 73 F250 Camper Special. Thanks!
F25HUS05848 UQ 23 F252 4 37J G A
F25 = F250 2WD
H = 390 2V
U = Louisville KY Assembly Plant
S05848 = 1973
UQ: U = Light Yellow Green / Q = Medium Lime Metallic
23 = ? DSO code? If so: Memphis TN Ford District Sales Office, where original selling dealer ordered the truck from.
F252 = F250 2WD Pickup / 7500 lbs. GVWR
4 = ? Could be trans code, but 4 not used except on F500's.
37J: 37 = Dana 60 / 3.54-1 / 5300 lb. Rear Axle Capacity / J = Power Steering
G = ? This also could be the trans code - if so = C6
A = ? Could refer to factory installed air conditioning.
Look on the Rating Plate, left door face near the latch.
Match the codes on the owner card with what you see on the plate...some of those codes make no sense, without knowing what they're for.
I'm no expert, but here's what I found.
F25 = F250 2WD
H = 390 2V
S05848 = 1973
F25 = F250 2WD
H = 390 2V
S05848 = 1973
It also has Ranger badges/trim. I'll compare it to the door tag like you suggested. Thanks again.
I had most of that typed then I realized it might the booklet card so I deleted it
The 4 stands for Styleside pickup
I think the A means Conventional pickup
Yours is the first card I have seen with that much info on it.
I have 3 of them to look at.
My 78 is lacking about 4 codes and I bought mine Brand new in 78
Originally Posted by Mil1ion
The 4 stands for Styleside pickup. I think the A means Conventional pickup.
In the car parts catalog: A = A/C, factory installed.
Bill here are 3 threads about this from way back
https://www.ford-trucks.com/forums/4...nd-papers.html
https://www.ford-trucks.com/forums/4...f-150-4x4.html
https://www.ford-trucks.com/forums/4...-question.html
[QUOTE=pcskies]
I've done some further research and found that for 1973 U=Limestone Green Poly, and Q=Winter Green. Please anyone correct me if my information is incorrect.
I can't confirm the codes, but I can confirm that sounds like a real kick-*** 70's color combo!
QUOTE
QUOTE
Here's mine
the original and the extended warranty
<a href="http://s262.photobucket.com/albums/ii99/mfix78/?action=view¤t=card.jpg" target="_blank"><img src="http://i262.photobucket.com/albums/ii99/mfix78/card.jpg" border="0" alt="Photobucket"></a>
maybe yhis should have its own thread
