00-04 5.4 or 6.8 SPD Y Pipe
For Sale
Engine - Exhaust
  • Engine - Exhaust - 00-04 5.4 or 6.8 SPD Y Pipe - New - 2000 to 2004 Ford F-250 Super Duty - 2000 to 2005 Ford Excursion - Port Orchard, WA 98359, United States
    Sold
    Sold
  • Price
    $75
  • Location Port Orchard, WA, 98359, USA
  • Condition New
  • Compatibility
Make Model Year
Ford F-250 Super Duty 2000 - 2004
Ford Excursion 2000 - 2005
Description:
If the ad is up its available. New, never installed, went with a Banks setup and its been sitting in my shop. Willing to ship but will need to add shipping on final price. It weighs about 3.5 lbs.
Fits 00-04 F250,350,450,550 5.4, 6.8
00-05 Excursion 5.4 or 6.8
This is a custom manufactured mandrel bent exhaust Y Pipe made here in the USA for the 2000 to 2004 F250, F350, F450, F550 & Excursion 2 wheel drive and 4 wheel drive 6.8L V10 and 5.4L V8 applications. It has two 2.5″ mandrel bent pipes transitioning to 3″. Ford’s factory y pipe downsizes to 1.5″ inch pipes which restricts the exhaust flow, forcing you to lose HP, torque and gas efficiency. Some of its benefits are: Its function is to free up the factory restricted exhaust connection, giving you more horsepower, torque, and gas efficiency. Our Y Pipe has two 2.5″ mandrel bent pipes transitioning to 3”. The factory Y Pipe downsizes to 1.5” inch pipes which restricts the exhaust flow, forcing you to lose HP, torque and gas efficiency. The dyno tests we performed show a gain of 33HP and 35 torque. This test was performed on a F-250 crew cab. You will get an extra 1-2 mpg. It is very easy to install. Just cut the old Y Pipe out and weld the new performance Y Pipe in. It comes with a coupler for easy install. Other Information: Due to legalese, I have to state that “this product is for off-road use only.” This product has not been approved by the state emissions department, however, it will not cause your vehicle to fail a smog test. Please check your Excursion/F250/F350 to make sure it has the restrictors. Somewhere during the 2000 year, Ford changed the exhaust design (there are two different exhaust versions for the year 2000, “old style” and “new style”). Ford installed the restriction points as an attempt to silence the exhaust flutter issue. Our Y Pipe was specially designed and tested as a more efficient fix for the problem. Other Y”s may not have the same results.
Old Jan 13, 2026 | 11:51 PM
CitrusDragon's Avatar
CitrusDragon
I am rather surprised no one jumped at this yet. How much shipped to 95660?
