20" non Widow Maker 5 hole wheels rims
For Sale
Wheels and Tires/Axles
  • Wheels and Tires/Axles - 20" non Widow Maker 5 hole wheels rims - Used - 1946 to 1957 Ford F4 - Jackson, WI 53012, United States
  • Price
    $200
  • Location Jackson, WI, 53012, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford F4 1946 - 1957
Description:
I have 11 20" with the five bolt hole pattern used on our old Ford. I also have one wheel that has a crack that has been welded that could be used on an inner rear wheel, I'd leave it up to some to determine if this would work.
Of the 11 wheels I have there are snap ring type wheels, these are not the dreaded two piece Widow Makers. These wheels can still be serviced by heavy duty truck shops.
I removed these from a 1942 Ford and a 1948-52 Ford truck. Over the years someone must have replaced their WMs with wheels from International, Dodge or Studebaker or Fords before Ford switched to the WMs. They come in a variety of widths. See the chart I included with the pictures.
 I want $200 a piece for these rims. Before you scoff at my price consider what I had to do to get these wheels that you do not have to. I found the trucks, I retreived the trucks, pulled the wheels off the trucks. Each wheel I had to remove the old tires which entailed prying the snap rings off, removing the dried on tires which were adhered to the wheels and took quite a bit of work. I also had to pay $15 a piece to properly dispose of the old tires. After removing the old tires each tire got an acid bath to remove rust and afterwards I used a wire wheel to remove remaining rust, dirt and paint. I sprayed on a couple of coats of implement primer to stave off rust forming again but I would suggest prepping the wheels and applying a better quality primer and paint.
The wheels are not in prestine, new condition. They are 80 years and have rust pitting but are still useable.
Check with your tire expert to assure you can use these wheels and they can mount new tires on them. I am not a tire or rim expert, I just know about old Ford trucks.
I am located in Jackson, WI and will ship at buyers' expense. Message me and I'll send you my phone number and we can discuss the rims further.
Old Nov 10, 2025 | 10:56 PM
wolfcoln's Avatar
wolfcoln
Hey, sounds like a fair price to me. How much to ship six to 48449. I just have to check with the truck place. Thanks
Old Nov 11, 2025 | 08:03 AM
bobj49f2's Avatar
bobj49f2
Originally Posted by b0bj49f2
Text me directly for a quick response so we can workout details 318-706-3742
This is a scam reply. The person(s) just set up this account and used a name close to mine with a capital "O".
Last edited by Y2KW57; Nov 11, 2025 at 09:55 AM. Reason: Drew a line through the copied quote of the scammer's post, so future speed readers would not text that number.
Old Nov 11, 2025 | 09:44 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Whoa... the scammer even copied your avatar!
We've seen a lot of 0 for O, I for l, and various permutations of common vowels with various glyphs above or below the vowel as found in other languages using the same vowel... but copying the avatar too?
Makes me want to take them down even faster.
We received your report (from the REAL @bobj49f2 ) and immediately banned the scamming imposter.
Old Mar 8, 2026 | 02:18 PM
wolfcoln's Avatar
wolfcoln
I found some wheels thanks for posting
Old Mar 8, 2026 | 02:25 PM
wolfcoln's Avatar
wolfcoln
I have found some. Thanks all
Old Jun 3, 2026 | 09:36 PM
bmaltb's Avatar
bmaltb
Trailering
rims non-wm
Do you still have some for sale? I have an 1949 f5 with split rims and ooold tires. Im in san diego.
Old Jun 3, 2026 | 11:49 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@bmaltb
The "b0bj49lf2" in the now deleted post was not the listing OP, whose username is "bobj49f2."
Observe the difference between spellings.
Everyone:
ALWAYS compare spellings of mid thread respondents implying that they are the OP, with the actual spelling of the OP in the first post that originated the listing.
NEVER respond to a phone number supplied in a post mid thread of a listing.
NEVER send money, buy gift cards, communicate, or transact with ANYONE without first verifying that you are dealing with is the actual OP, by visiting the user profile of the originator of the listing, and using FTE's Private Message system to initiate communication.
ALWAYS suspect ANY respondent to ANY marketplace listing mid thread. We endeavor to extinguish scammers as soon as they appear, but like evil in all forms, it always reappears.
