1997 OBS 7.3 manual 4x4 Dually
For Sale
1997 Ford F-350
  • 1997 Ford F-350 - 1997 OBS 7.3 manual 4x4 Dually - Used - VIN 1FTHF36F0VEB06487 - 176,000 Miles - 8 cyl - 4WD - Manual - Truck - Gray - Coral Springs, FL 33065, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
Trailering
  • Price
    $13,000
    • OBO
  • Location Coral Springs, FL, 33065, USA
  • Condition Used
  • VIN 1FTHF36F0VEB06487
  • Mileage 176,000
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Manual
  • Vehicle Type Truck
  • Exterior Color Gray
Description:
This is my 1997 Ford F-350 Regular cab, dual rear wheel, manual 7.3. Very rare combination. I have a ton of money invested into this truck.
 It drives great, AC is cold, 4x4 works, new clutch and tons of new parts I’ll list below. Cab corners are rusty but frame is solid, not really any rust besides the cab corners. Paints 10’ paint, starting to get a nice patina to it. Good from a distance, not great up close. Very hard to find this combination.
 Quick release oil drain
New seat
Riffraff boots
Locking tailgate/ bed mat/ bed rail caps
Brake fluid
Coolant temp sensor
Traction bar bushings
Tie Rods
Fuel tank switch valve
Added pickup tube to rear sending unit and changed gasket
Fuel strainer
Front sending unit
Tailgate bushings
Alternator
Windshield clis
Transmission/Transfer case fluid change
Fuel bowl delete, electric fuel pump (CRUDE DIESEL
HPOP CNC Fab
IDM
Rear passenger Injector pigtail
IPR pigtail replaced
Valve cover Gasket Harnesses
ICP sensor
IP
Glow Plugs
Tires (Toyo Open Country)
Exhaust
Side window vent
Ac vent,
Clutch master and slave cylinder and fuel hoses
Rear Brake shoes, wheel cylinders, rear axle seals, driver side hardline rear half inch wheel spacers, alignment , driver outer tiered
Clutch and flywheel
Belt
Tensioner
Master cylinder
Old Apr 25, 2024 | 07:31 PM
Ford15000's Avatar
Ford15000
2nd Gear
I like it but I am in Michigan.
Old Apr 25, 2024 | 07:34 PM
disturbinglee's Avatar
disturbinglee
Trailering
Well you’d have much better luck getting something rust free down here I’m sure haha
Old Apr 26, 2024 | 05:48 AM
Ford15000's Avatar
Ford15000
2nd Gear
For Sure can you send those pictures to powerking1614@gmail.com
