11 thru 22 Super Duty OEM Ford 5th Wheel Hitch Puck 3” Outer puck Ring trim
Wanted
Miscellaneous
  • Miscellaneous - 11 thru 22 Super Duty OEM Ford 5th Wheel Hitch Puck 3” Outer puck Ring trim - Used - 2011 to 2022 Ford 1 Ton Pickup - Brighton, CO 80601, United States
    Expired
  • Price
    $5 - $6
  • Location Brighton, CO, 80601, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford 1 Ton Pickup 2011 - 2022
Description:
No longer needed.  Thanks
Old Dec 14, 2022 | 06:34 AM
wmasmith's Avatar
wmasmith
6th Gear
If you don't mind my asking, what did you end up doing? I need the insert for the outer holes. I don't feel like buying a whole kit again.
Old Dec 15, 2022 | 12:24 AM
Shred's Avatar
Shred
I found a used set of the rings that go on outside of holes for really cheap. Do you need the piece that pushes in the puck itself? Can’t help with that. Sorry.
Old Dec 15, 2022 | 06:54 AM
wmasmith's Avatar
wmasmith
6th Gear
Yeah unfortunately I need the inside piece. One of my sons knocked it out when we to the dump last time and just swept it out with the rest of the dirt and stuff. He didn't bother to think hey that's not supposed to be out of the hole. Thanks anyway.
