3 Ford f250 supercab trucks
For Sale
1977 Ford F-250
  • 1977 Ford F-250 - 3 Ford f250 supercab trucks - Used - VIN X25sky44591 - 8 cyl - 2WD - Automatic - North Fairfield, OH 44855, United States
    Sold
    Sold
    Sold
  • Price
    $2,800
  • Location North Fairfield, OH, 44855, USA
  • Condition Used
  • VIN X25sky44591
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
Description:
I have three super cab trucks for sale all two wheel drive, m motors, and automatic transmissions, two have clean titles, one does not.  2 are long beds and 1 short bed. and I also have a bear supercab cab as well as a lot of 79 and older truck parts calls are highly preferred over any form of messaging please
Old Dec 14, 2022 | 10:21 PM
Xian's Avatar
Xian
Trailering
can you provide a way to contact you? I am looking for a 78-79 f100 lower portion of the steering column. It would be for a tilt (doesn’t matter same part for non tilt) steering wheel, RWD (non-4x4), automatic, & has a power steering box. The part connects directly to the spline of the steering column and then the rag joint on the other side. The rag joint then connects to the power steering box. Here is the Ford Diagram and the Ford part number is D8TZ-3A528-A and it is called a steering housing assembly or a steering column shaft coupler.
Highlighted part is what I need.
Here is the full diagram.
And I believe this is the part numbers. Small on this screen so not sure if it is the correct attachment.
Old Dec 15, 2022 | 06:57 AM
Lonewolf7's Avatar
Lonewolf7
My number is on the picture of business card in pictures of trucks.
