Looking for early Clark 5speed Overdrive.
Wanted
Drivetrain
  • Expired
  • Price
    Any Price
  • Location Clarkston, WA, 99403, USA
  • Condition Used
Description:
Looking for Clark 5speed Overdrive transmission for my 1960 3/4 ton 4x4.
Old Aug 24, 2022 | 07:43 PM
magic_energy's Avatar
magic_energy
4wd Low
I think I do have a Clark 250V or according to the warranty plate a clark 265V. Not sure which yet. It has a pto built into it. Came from a 1961 F600 mason dump truck.
Old Aug 25, 2022 | 12:09 AM
idaho211's Avatar
idaho211
Thanks for the reply. I am looking for a 251VO.
Its a medium duty 5 speed OD
Tranny code K 57-60’s. Would have to id on tranny because K tranny code could mean 5speed direct drive without overdrive.
Don
Old Aug 25, 2022 | 07:50 AM
magic_energy
4wd Low
The K in this chart does not correspond???? Wrong year?
Old Aug 25, 2022 | 07:57 AM
magic_energy
4wd Low
Oh, maybe that is the direct drive you mentioned. These old ford truck transmission sure did come in a bewildering variety and the proper identification is not easy and yet it is essential.
Phillip
Here is mine.
Old Aug 25, 2022 | 08:22 AM
idaho211's Avatar
idaho211
Thanks for the info. Does it have any other numbers on the case? 251VO-9 or 251VO-17 are the two I am looking for.
K was the letter on your data plate for the transmission code. A “K” could also mean 5speed direct drive.
Old Aug 25, 2022 | 08:26 AM
magic_energy
4wd Low
Yes it does. I will take a picture later on today and send it to you. It is not engraved or on a plate. It is just painted on with yellow paint in big block letters.
Old Aug 25, 2022 | 08:40 AM
idaho211's Avatar
idaho211
Phillip,
What size of engine do you have?
Don
Old Aug 25, 2022 | 08:45 AM
magic_energy
4wd Low
292 Y block. It was a beautiful engine. I sold it a couple of years ago. Hated to do it. Compression tests were good except down a little in only one cylinder and not all that bad in that one.
Old Aug 25, 2022 | 09:03 AM
idaho211's Avatar
idaho211
Phillip,
I put in a 312 in my 60 3/4 ton 4x4. I was looking to switch out the 4speed for the 5speed OD because its a direct bolt on.
So I checked and the case number 224716 was used by 250V and 251VO. I will have to look and see if there is more Id marks. Thanks for the reply.
Don
Old Aug 25, 2022 | 06:26 PM
magic_energy
4wd Low
Don, Here is the marking on the other side of the transmission.
Says "C-5TA"
Old Aug 25, 2022 | 09:39 PM
idaho211's Avatar
idaho211
Phillip,
Thanks for the pic. From the ID it is a 5 speed direct drive. Darn. I was hoping it was an overdrive. I guess the search continues.
Thank you for taking the time to help me.
Don
Old Aug 26, 2022 | 09:55 AM
magic_energy
4wd Low
Don,
What was the reference you used to determine that the 224716 number was a 250V or 251VO?
Phil
Old Aug 27, 2022 | 12:18 PM
idaho211's Avatar
idaho211
So the case number 227416 can be either a 250V or 251VO for Y blocks and I found it Roadranger.com interchange pdf. The painted number on the cover id is from my ford parts manual 57-63 which indicated it was a 250V.
Old Sep 12, 2022 | 11:53 PM
andyh1956's Avatar
andyh1956
Get on the H.A.M.B. in the classifieds. There was one that was advertised a few yrs back & was never marked as Sold. There is another Clark 5 speed in there now but don't remember if it is what you're looking for, the 1st one was.
