I’m interested and only a couple hours away from you. But I need 6 if I could find one anywhere and have it shipped I’d buy yours in a heartbeat but well you already know how hard these are to find. I’ll keep trying and let you know thanks
Hi craftsmangary, these look like a good fit to upgrade my 52' f6 with. I'm new to all of this, does the offset work with the f6 as it does your f4? I have the marmon Herrington conversion. I'm in BC Canada, right above Idaho. Is it possible to figure out shipping? I Wouldn't know where to begin stateside for that? Ian
I'm going to see what it takes from my end. Rims like that are hard to find here in Canada. If there still around in a bit, I may have a solution for us both. Thanks for the reply, Ian
I can get the stuff on a pallet and load it on my end. I'm sure you don't want these old tires, so I'd probably have to get those busted down.
Are you interested in the complete front and rear axles? It's probably a nice upgrade for these older trucks.
I've shipped big parts before on pallets through Fastenal. Maybe check see if you have one in your area and start with them. The closest Fastenal to me is Wixon Michigan and that's where I've dropped stuff off at before.
Yes, I would take it all depending on the total price. What is the rear axle ratio?
I do have a local Fastenal and will check with them on shipping.
