I have a lot of used parts left over from my '62 F100 project that are serviceable and someone may need. If you need any of the parts contact me via PM or call/text 662 609-1080 for info or pictures. I'm located in Warsaw, MO.
Flairside tail gate, has 12" rust spot on top roll over that is repairable, hinges included/ 4 15/5 innie wheels 5 on 5.5 bolt pattern true but need painting/ 2 sets clear parking light lense sets, one new with screws and gaskets the other used/ front brakes with drums, backing plates with every thing attached, master cylinder/ wheel bearings and brake lines/ FORD grill letters/ front hood emblem/ door handles/ 2 side view mirrors/ 223 intake manifold with linkage brackets/ heater core/ heater control valve/ 2 speed heater fan switch with defrost cable/ low hump rubber floor mat.
