1965 to 1972 F100 rear leaf springs
Wanted
Wheels and Tires/Axles
  • Closed
  • Price
    Any Price
  • Location Olive Branch, MS, 38654, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford 1/2 Ton Pickup 1965 - 1972
Description:
Looking for a set of rear leaf springs, 1965 to 1972 F100. Mine came with some "torch modified" springs. Home made lowering kit.
Old Dec 7, 2019 | 07:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the truck? If a 1968/72, does it have Flex-O-Matic rear springs?
Old Dec 7, 2019 | 07:36 PM
Tedster9's Avatar
Tedster9
If there any large truck repair shops nearby they can usually make a set of leaf springs for your truck. Price should be competitive too - shipping charges can be hefty. Eaton Spring out of Detroit was a major supplier for the OEM and has the original blueprints and makes a quality spring.
Old Dec 7, 2019 | 08:15 PM
rdixiemiller's Avatar
rdixiemiller
Bill
it’s a 1965, standard springs.
Some yahoo heated the rear side of the springs, about 3 inches from the rear eye, until they bent 90 degrees or so.
Cutting torch lowering kit........
Old Dec 7, 2019 | 08:17 PM
rdixiemiller
Cost.....
just trying to keep the cost down. Looks like springs are 160 to 230 each, plus 35 bucks shipping per spring!
The junkyards around here don’t have much that is that old.
Old Dec 7, 2019 | 08:38 PM
NumberDummy
Bill
Excepting 1968/72's with Flex-O-Matic, 1957/72 F100 2WD rear springs interchange.
Old Dec 7, 2019 | 08:51 PM
rdixiemiller
Thanks Bill!
you’re an outstanding resource!
Old Dec 7, 2019 | 09:12 PM
SAndrus00's Avatar
SAndrus00
I have a set from '73-'79 if they will work. I can measure if need be and send pictures. $250 OBO plus shipping I'm at 70535 if you want to check shipping
Old Jan 1, 2020 | 08:26 PM
SjoDon's Avatar
SjoDon
I got mine from General Spring for $300 for both sides. They even have the bushings already installed. Very quick delivery.
Old Jan 2, 2020 | 02:59 PM
cqs2506's Avatar
cqs2506
i have a set about an hour away from you will take $100
