LF: C6 transfer case adapter. 460 alternator and power steering brackets
Wanted
Drivetrain
  • Drivetrain - LF: C6 transfer case adapter. 460 alternator and power steering brackets - Used - Airdrie, AB T4B 0S, Canada
    Expired
    Expired
  • Price
    Any Price
  • Location Airdrie, AB, T4B 0S, Canada
  • Condition Used
Description:
Im almost done with my 460 swap into my bronco but hit a few last minute snags. We broke the transfercase adapter on my junkyard c6 core while trying to remove it. Someone thought it would be a good idea to mount the transmission solid to the frame so i assume it stressed the adapter. Also my 460 core that we assembled doesnt have alternator or powersteering brackets, or waterpump/crank pulleys either.
Looking For
C6 Transfer case adapter. The one i have is D8TP-7A040AA . But i think any adapter will work as long as its from a C6. The adapter from my stock bronco does not work
460 Alternator bracket
460 powersteering bracket
460 crank pulley
460 water pump pulley
My ultimate goal would be to get a complete bracket setup off a fuel injected 460 van. but at this point ill take any matching bracket setup.
I am in Alberta, Canada so i know shipping might be expensive on some of these items, but im running out of options. There is zero 460s in the 3 pick n pulls here. And it took me almost 3 years to find decent deals to get my build this far.
Old Jul 27, 2019 | 02:45 PM
quesey's Avatar
quesey
I think I have most of what you are looking for
Old Sep 9, 2019 | 10:54 AM
OhioFordFarm's Avatar
OhioFordFarm
Let me know if your still looking for the adapter. I might have one kicking around here.
Side note or question. Did you have to change the cross member under the motor for the 460? The cross member I have in my truck was for a 300 or small block. The oil filter adapter hits my cross member.
