Burst of hot air when taking off
so now that the temps are getting cooler, but not really cold i keep the heater on hot with low fan setting on defrost, when im driving my 7.3 diesel 2000 excursion, it seems when i accelerate i get a burst of hot air from the defroster, i was wondering if anyone else experiances this?
and is there a way to fix it? or is it just normal? it puts out good heat at idle and everything, it just seems when i accelerate from a stoplight i get that eye drying burst.
The burst of speed and resulting G forces push you further back into the seat, thus putting you into the path of the otherwise naturally occuring draft zones of the HVAC system of your truck.
That or the fan motor has an iffy ground that is impacted by the above noted inertial change???????
Or better yet, the coolant level is a tad low in the radiator system and gets a little extra boost with the increased RPM's upon acceleration.
BTW, it's still damn near a hunnered degrees and almost a humidity percentage to match here. I will gladly swap ya, but only for a very few weeks.
