rear end sag
Hmmm. Piecemeal lifts usually don't work out so well.
Look at the rear leaf springs. Is there a newer leaf mixed into the old leafs? Should be the second or third leaf down.
If yes, then you may need to add another one to the rear. If not then add an add-a-leaf.
Then again, just how big are your tires? Do you really need that big of lift?
Just curious.
Oh, just looked at you sig.
37s only need 5-6 inches lift to not rub for normal street driving. They rub offroad with less than 8" lift in the front. And some trimming....
Ditch the Banks transcommand and get the Sonnax valve and Tricumulator springs. Look it up on google. Been running these for many years.
Just curious.
Measure the block currently installed. If they are 2", then they are stock F250, in they are 4.5"-5" Then they are F350. if you have the shorter blocks then go get the taller blocks.
Get a pair of F350 blocks. (5")
Or Superlift has 5" blocks that have a taper built into them for pinion angle. I had them prior to no blocks.
when i lifted my truck ten years ago i installed the add a leaf and blocks. after ten years she is sagging in the rear. since you do not know how long the lift has been on or what has been done i would think you have a couple options, install new springs in the rear or add more blocks, have the springs re arched or install air bags to help level the truck out. good luck and let us know how things go.
On my 06 F350 I ordered a lift for a 250 to get the bigger rear block. But I had to have longer U-Bolts custom made.
Ya I was told the same thing by buddies that it has that sag like a dog in the woods, from the gate. Don't know why anyone would want to accomplish this look but to each his own I guess. I think adding a leaf would work out best. Any pros or cons compared to blocks you guys can think of, thanks
