2001 Navi: AC Problem
Old Aug 9, 2010 | 01:43 PM
Lance Hogan's Avatar
Lance Hogan
I primarily hang out in forum 41 (1948-60), but am experiencing a problem with my wife’s 2001 Lincoln Navigator air conditioning system and want to see if you guys can help me figure out what is going on. When we drive the vehicle, the AC works great. When we come to a stop and idle, the AC system begins blowing warmer air. Any help on identifying the problem would be much appreciated.
<O</OLance<O</O
Old Aug 9, 2010 | 05:14 PM
alloro's Avatar
alloro
Oh sure, first your ignore us for the company of another forum, then you have the nerve to come crawling when you need help.
The first thing to do is hook gauges up and make sure the system is full of R134a refrigerant. If it's low then that's the problem. If it's not low, then you're not getting enough airflow across the condenser in front of the radiator. This could be due to debris (leaves) in there, dirt, or perhaps the radiator clutch fan could be worn and slipping. In the case of the fan clutch, when it slips it does not draw as much air through the condenser and the radiator.
In case none of these ideas help you, there's also an air conditioning/heat forum here on this site.
Old Aug 9, 2010 | 05:29 PM
Lance Hogan
Thanks for the quick response.
Yes, I am begging for your help. The wife won't get off my butt!!
I don't have the gauges to check the A/C so, I will need to take it to the shop.
Again, thanks...
Old Aug 9, 2010 | 05:32 PM
alloro's Avatar
alloro
It's less expensive to buy the gauges than it is to go to a shop. Plus you'll have the gauges for next time.
Old Aug 10, 2010 | 12:25 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
It's a whole lot easier to check for blockage in front of the condenser first.
Old Aug 10, 2010 | 06:41 AM
projectSHO89's Avatar
projectSHO89
...or to go the the forum specifically dedicated to HVAC issues and read the FAQs there...
Truckandute
Aug 28, 2014 01:42 PM
TexasEX2K
Jul 5, 2012 10:46 PM
5Rangers
Jul 25, 2011 09:42 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
lorenambrose
3.0L V6
Jun 26, 2010 07:53 AM
