I have an 85 302 thats rattels sumtimes when i put a load on the motor or if i go up a hill, plus i have no power the fastest i can go is about 55mph what could be wrong? im sure its in time idk what it would be
It could be several things. I'd start by checking the timing. Make sure it's at the spec on the radiator support.
I'd also check to make sure the radiator was full of coolant (so it can't run hot) and look for vacuum leaks. A vacuum leak would give the engine a lean fuel/air ratio, which can make the engine knock.
Frank
I would check the heat riser valve if you have one. It's the valve in one of the exhaust pipes leaving the engine. If it's stuck shut, it's going to zap the power of the engine, and it also going to make the engine run a little hot.
I had the same problem when I installed headers on my 351w. The main problem was the headers reduced the backpressure so much, the EGR wasn't working properly anymore. So this is what I tried;
1. Colder rated sparkplugs-didn't make much difference.
2. Richer jets in the carb-little bit of difference in the pinging, but didn't totally go away. But richer jets really made a difference in how it ran down the road, big improvement in that department. But I was running the stock carb, if you are running a aftermarket carb, you jetting is probably ok.
3. Changed from a 195 degree thermostat to a 180. This fixed it. Most all the pinging went away when I changed the thermostat to a cooler one.
I could have retarded the timing to help the pinging, but I always seem to lose power when I do this, and my dist was stuck and would not turn anyway, so I left the timing at the stock setting(I did check it and it was at the stock setting).
i put a holley 4bbl on it plus put a 180 thermostat in it and it still does it
Disconnect the vacuum line to the distributor and plug it. Then run it like that and see if it goes away.
If it does, I have been down this road before on another engine I had (302). It seems the factory sets the static timing very conservative, and then runs lots of advance with the vacuum. When I modified my engine(higher compression pistons, 4bbl, etc) I used the stock dist and I found the vacuum advance was going overboard in that department. I just ran it with the vacuum disconnected, but I was going to buy an adjustable vacuum advance for it, but I never got around to it before I pulled that engine out.
The vacuum advance is for fuel mileage only, it won't hurt anything else to run it disconnected.
