ok, so we all wonder what color our interior is when we want to re dye it. On my truck there are actually 2 different colors, the dash is Dark Graphite and the rest of the truck is Medium Graphite with Dark Graphite inserts. i looked on this forum for at least 2 hours tying to find what I needed but all I found was a bunch of confusing numbers and letters. It took me and my local ford dealer about 45 minutes to find what the interior code on my truck ment which is "F2" F stands for Graphite and the 2 stand for 2 tone graphite which is in this case is Medium and Dark Graphite for that specfic code. Instead of ordering a 6 oz can of spray bomb from the dealer yet again I found some SEM Classic coat for $12 bucks a can. If anyone needs the code for Dark graphite it is 17083 , Medium Graphite 17043 and its the SEM Classic Coat. If you want to get it from your dealer the codes are: Ford Med Graphite PM-19M547-4245H Ford Dark Graphite: PM-19M547-4253H. The dash now looks perfect and no more black spots, and it all matches the 10 year old stuff!!!
Blitz, I have the same problem as you originally did. Can I ask you a question? Which color went on which part of the dash? I need to touch up the top dashboard, that goes back to the window. I also have a 2000 f150. Do I need the medium graphite or dark graphite? It sounds like dark was the top of the dash and the medium the front view? Just wanted to double check before ordering. Thanks!
