What are the differences between 3/4 dana 44 and 1/2 dana 44?
Old Jun 27, 2010 | 08:35 PM
hasteranger's Avatar
hasteranger
I have a 78 F150 I picked up a couple weeks ago and I got it running and driving today. its gonna be a tow vehicle and I plan on using it on smaller trails that my other truck won't fit on. Its got a 351M/c6/205 with the 1/2 ton dana 44 front and 9" rear (obviously).
We have a parts truck, its a 77 low boy F250 with dana44 front with the 8 lug hubs, and a dana 60 full floating rear with 4.10's and a limited slip that doesn't work all that great. I'd like to swap the axles under mine (if I don't end up swapping the frame) for the lower gears, the higher capacity rear end, the 8 lug bolt pattern (I have a nice set of rims I wanna put on it) and the bigger front brakes.
so my question is, if I try to keep the coil springs, whats the differences between the axles? seems to me like I could swap over the bigger brakes and 8 lug hubs and swap out the internals from the 3/4 ton axle over to the 1/2 and then not have to worry about rewelding the hardware for the radius arms and coil springs.
Old Jun 27, 2010 | 09:28 PM
mark a.'s Avatar
mark a.
Yes, you can do just that.
Old Jun 27, 2010 | 09:47 PM
c.l.nye's Avatar
c.l.nye
X2,you can swap all the brake and spindle parts from the 250 front to the 150 knuckles,it is a bolt on deal.
Old Jun 27, 2010 | 10:44 PM
hasteranger
I figured so, just wanted to double check. thanks! Does anyone know if the Dana 60 and the HD dana 44 used the same rotors?
Old Jun 27, 2010 | 10:55 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Yes. Rotors, calipers and caliper brackets are the same.
1972RubberDuck
16
Nov 12, 2016 01:30 PM
Eli1644
13
May 5, 2014 05:50 PM
amosmoses
Dec 19, 2013 07:32 AM
ahuggins6
Oct 7, 2012 12:42 PM
fishindave11
1978 - 1996 Big Bronco
Jun 15, 2012 04:21 AM
