Rear Dana 60 diff plug tool size
Old Jun 27, 2010 | 08:01 PM
jasonnerothin's Avatar
jasonnerothin
Question Rear Dana 60 diff plug tool size
Anyone know what kind of a tool I need to pull the differential grease plug on a Dana 60 (rear)? I was planning on just doing it tomorrow morning, but it looks like an "innie", not an "outie".
Looks to be something between 5/8 and 7/8, but that's me just guessing...
Old Jun 27, 2010 | 08:05 PM
jasonnerothin
Talking
And while I'm at it: There's a 4-way fitting welded (?) between the brake backing plate and the U-bolts/springs. Three go to brake, one to a loose hose - vacuum, from the looks of it... My guess is this hooks into the rear diff to provide vacuum assist to the brake system, but I don't know where the other end is supposed to go. "Breather"? and where do I find it? Truck came with it laying atop the gas tank...
Old Jun 27, 2010 | 08:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The loose hose has nothing to do with vacuum. It's hooked to the axle vent. This keeps pressure from building up inside the axle housing when it warms up to prevent leaks. The hose raises the vent higher up to help keep water and mud out. It should be cliped to the upper part of the frame rail.
Don't know about the wrench size though, but if it's a square drive try a 1/2" ratchet. If that's not big enough it's probably 3/4". You could measure it with a tape to see.
Old Jun 27, 2010 | 08:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
This is an F100 w/ a Ford 9" rear but the idea is the same on the axle vent
Old Jun 27, 2010 | 09:56 PM
jasonnerothin
Cool, thanks... So I'll just mount her up somewhere out of the way and expect it to vent normally.
That design has lines to each rear wheel (with the larger diameter tube to on the top going the distance to the right rear)?
Old Jun 27, 2010 | 10:40 PM
fellro86's Avatar
fellro86
There are no brake lines on the axle in that pic, the line you see is coming from the master cylinder. The brake lines would come from the brass block on the axle tube if it were completed at the time of the pic.
Old Jun 27, 2010 | 10:45 PM
mikeo0o0o0's Avatar
mikeo0o0o0
In the picture the flexible brake line is the feed from the master cylinder, when I took this picture, the hardlines that go to the right and left wheels hadn't been installed yet. This is a picture of the left (drivers side) rear wheel. Although the brake hose appears to go to the rear, if you look closely you can see that the hardline that's connected to the hose does a 180 and actually runs towards the front.
Old Jun 27, 2010 | 11:03 PM
jasonnerothin
So what's the larger diameter hard line - looks like it makes a turn in the direction of the... fuel line... of course.
Now I've gotchya. Thanks for the explanation.
Learning. Slowly, but at least I'm learning
Old Jun 27, 2010 | 11:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, the larger hard line is the fuel line.
mustanginca
Feb 9, 2008 06:33 AM
f250rangerexplorer
May 11, 2005 03:09 PM
diesel460
Aug 17, 2004 09:56 PM
69crewcab
Jul 13, 2004 08:37 PM
