installing V springs in the front ONLY?
I will be installing new V springs in the front of my 01 Ex and I wanted to know since I am keeping the factory springs in the back what I should do to make sure the Ex doesn't sit front end high.
do I need to install a taller block in the back with the original springs? if so do which block do I go with, a 3.5" tapered block or a 3.5" flat block or no block at all?
to help answer the question all I tow is a very small landscape trailer with Polaris Ranger so nothing too heavy.
can I get away with keeping my stock rear springs?
thank you in advance for you time and help
www.partsguyed.com
Years ago, when I researched this mod, the blocks were referred to as 3.5" tapered blocks, so that's what I've always called them.
Left side 3.5" tapered block: Part #F81Z-5598-FA
Right side 3.5" tapered block Part #F81Z-5598-GA
Stewart
It would be nice if one of these was around for the rear axle as well; maybe for the springs and the blocks.
(For stock Excursions the) Front axle weights used are 4080, & D code springs for the PSD and 3680, & C code springs for the V-10.
Application---Code---Capacity-----Rate----Travel --------- V-10 ----- PSD
------------------------------------------/spring---to Max Cap ----height ----height
------------------------------------------------------------------------ change --- change
Exc V8 --------- B ----- 4100 ----- 330 ----- 5.02 ---------- -0.25 ----- -0.66
Exc V10 ------- C ----- 4300 ----- 350 ----- 5.01 ----------- 0.00 ----- -0.37
Exc PSD ------ D ----- 4700 ----- 380 ----- 5.14 ---------- +0.33 ---- 0.00
F250/350 All springs are computer selected
Also the use of a rear sway bar and what size it is package dependent
Application---Code---Capacity-----Rate------Travel --------- V-10 ----- PSD
--------------------------------------- /spring---to Max Cap ----height ----height
SD-250/350
------------------ S --------4000 ----- 370 ------ 4.34 --------- +1.22 --- +0.88
------------------ T --------4400 ----- 390 ------ 4.63 --------- +1.42 --- +1.11
------------------ U --------4800 ----- 410 ------ 4.89 --------- +1.60 --- +1.32
------------------ V --------5200 ----- 430 ------ 5.13 --------- +1.77 --- +1.50
F450 ----------- W --------5600 ----- 450 ------ 5.34 --------- +2.77 --- +2.52
F550 & 350/ DRW with Snow Plow prep Package
------------------ X-------- 6000 ----- 470 ------ 5.54 ---------- +2.90 --- +2.68
...and somewhere else I found this parts list with part numbers for a V & B code swap (I apologize to whoever wrote this list, I honestly can't remember where I found it):
Here's my order:
<table class="MsoNormalTable" style="width: 4.75in; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="456"> <tbody><tr style="height: 15.75pt;"> <td style="width: 191pt; padding: 0in; height: 15.75pt;" width="255"> FRONT SPRING V CODE SPRING
</td> <td style="width: 49pt; padding: 0in; height: 15.75pt;" width="65"> 2
</td> <td style="width: 102pt; padding: 0in; height: 15.75pt;" width="136"> 2C3Z-5310-HA
</td> </tr> <tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> <st1:stockticker>AXLE</st1:stockticker> TO SPRING U BOLT
</td> <td style="padding: 0in; height: 15.75pt;"> 4
</td> <td style="padding: 0in; height: 15.75pt;"> F81Z-5705-ZA
</td> </tr> <tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> <st1:stockticker>AXLE</st1:stockticker> TO SPRING U BOLT <st1:stockticker>NUT</st1:stockticker>
</td> <td style="padding: 0in; height: 15.75pt;"> 8
</td> <td style="padding: 0in; height: 15.75pt;"> N805480-S426
</td> </tr> <tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> SD Ford front Bump stops
</td> <td style="padding: 0in; height: 15.75pt;"> 2
</td> <td style="padding: 0in; height: 15.75pt;"> F81Z-3020-DA
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; height: 12.75pt;">
</td> <td style="padding: 0in; height: 12.75pt;">
</td> </tr> <tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> REAR SPRING B CODE (w/o aux)
</td> <td style="padding: 0in; height: 15.75pt;"> 3C3Z-5560-CB
</td> </tr> <tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> 3.5” BLOCK LEFT (Tapered)
</td> <td style="padding: 0in; height: 15.75pt;"> 1
</td> <td style="padding: 0in; height: 15.75pt;"> F81Z-5598-FA
</td> </tr> <tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> 3.5” BLOCK RIGHT (Tapered)
</td> <td style="padding: 0in; height: 15.75pt;"> F81Z-5598-GA
</td> <td style="padding: 0in; height: 15.75pt;"> N811667-S436
</td> </tr> <tr style="height: 16.5pt;"> <td style="padding: 0in; height: 16.5pt;"> <st1:stockticker>AXLE</st1:stockticker> TO SPRING U BOLT <st1:stockticker>NUT</st1:stockticker>
</td> <td style="padding: 0in; height: 16.5pt;"> 8
</td> <td style="padding: 0in; height: 16.5pt;"> N620485-S441
</tbody></table>
If you prefer the F-codes, here is the info (they are more expensive):
<table class="MsoNormalTable" style="width: 4.75in; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="456"> <tbody><tr style="height: 15.75pt;"> <td style="padding: 0in; height: 15.75pt;"> REAR SPRING F CODE SPRING
</td> <td style="padding: 0in; height: 15.75pt;"> 6C3Z-5560-F
</td> </tr> </tbody></table>
Hope this helps,
Stew
That chart is in Excel format and i've sent it to many a person over the years. I'm sure Monsta got it from Bruce, just like I did all those years ago.
That chart is where all the height quotes you see posted comes from.
Stewart
