remove left rear inner tire
Old Apr 19, 2010 | 11:57 AM
lars andersson's Avatar
lars andersson
Smile remove left rear inner tire
Hi
I have a Ford Truck 1 1/2 ton from 1940 and now i must remove the tire.
The first outside was no problem but next.
Someone who know howe to do?
Remove the bolt with square , left threaded ?
Please give me tips
Old Apr 19, 2010 | 01:37 PM
Fighter-of-Wars's Avatar
Fighter-of-Wars
Yes, the square headed bolt is removed with a 13/16 wrench. It is threaded onto a smaller bolt that is attached to the drum. It had me confused for awhle aswell. I believe you turn them the same direction to loosen as the lug nut was. They will be pretty tight, atleast mine were, I broke 1 cresent wrench and bent 3 13/16 wrenches trying to get them off.
Old Apr 19, 2010 | 09:13 PM
dbdbb's Avatar
dbdbb
They do have a socket made for those 13/16" squares. I bought a socket at Napa that has both the 1.5" hex and 13/16" square all in one socket. Usually right side has a right hand thread and the left side has a left hand thread. An impact wrench really helps.
Old Apr 19, 2010 | 10:28 PM
51504BAT's Avatar
51504BAT
Be careful dealing with the split rims on this truck. Search the forum for "widow maker" rims that trucks of this vintage may have.
Old Apr 21, 2010 | 08:57 AM
petey shoes's Avatar
petey shoes
they are called ---cones and nuts--- the cone holds the inside wheel to lug. these are stamped on head with either--lh-- or--rh. left hand or right hand. pertains to thread direction. they do make a cone socket, available at most auto parts dealers, (napa etc)
Old Apr 29, 2010 | 03:29 PM
lars andersson
thanks for all help.
DanielC
Aerostar
48
Jun 26, 2020 10:18 PM
sonneborn3
Aug 2, 2013 04:15 PM
Emel
6.7L Power Stroke Diesel
Sep 19, 2011 06:50 PM
frankat1
Mar 12, 2009 09:25 PM
