64 f250 4x4 help numberdummy,camperspecial65,anyone
Brand new to this site, but glad to be here. I have a 64 f250 4x4 I bought when I was 15 for 100 bucks from a local farmer. It survived through two different owners and 5 teenage boys. I am going to try to restore to close to original. Here is the info. F26CR491506 WB 120 Color JM Model F260 Body N81 Trans. F Axle 24 Max GVW 6800 Cert. Net HP 135 RPM 3800 DSO 733613. Hope you can give me as much information from above as possible. Also, I have 1964 f250 2x4 and was hoping to use the body and bed on the 4x4 frame/chasis. Will the bed work or does it have to be the correct 57-60 style bed? Thanks to all willing to help me out.
Here is the info. F26CR491506 / WB 120 / Color JM / Model F260 / Body N81 / Trans F / Axle 24 / Max GVW 6800 / Cert. Net HP 135 / RPM 3800 / DSO 733613.
Welcome to FTE
F26 = F250 4WD.
C = 292 2V.
R = San Jose CA Assembly Plant.
491506 = 1964, assembled January 1964.
120" Wheelbase.
JM: J = Rangoon Red / M = Wimbledon White.
F260 = F250 4WD / 6800 lbs. GVWR
N81: N = Red Crush Vinyl & Red Check Stripe Woven Plastic / 81 = 81A Standard Cab.
The bed has to be the 57-60 single wall style bed...IMO...on the 4WD and it being higher up then the 2WD counterparts...its a more aggressive looking stance...
