accelerator cable firewall mount part #/source request
Old Feb 19, 2010 | 11:55 AM
carras's Avatar
carras
Any pointers to a part number and/or source for this mount would be appreciated. Salvage yards around here (Chicago area) don't keep older trucks around. Thanks
Old Feb 19, 2010 | 12:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are FIVE different mounting brackets.
What year is the truck, what size is the engine?
Is the truck 2WD or 4WD?
If this is a 1966 F100 2WD w/a 240, does it have a smog pump?
Old Feb 19, 2010 | 12:44 PM
carras's Avatar
carras
Thanks ND
Truck is a 1966, 2WD with an FE (352) 3 spd manual
The picture I used from BillW previous posting because I thought that it would be better to show the picture rather than get the name wrong
Old Feb 19, 2010 | 12:58 PM
NumberDummy
Truck is a 1966, 2WD with an FE (352) 3 spd manual.
The picture I used from Bill W previous posting because I thought that it would be better to show the picture rather than get the name wrong.
Excellent idea...I wish more ppl would do this, because a picture says a thousand words.
C5TZ9728A .. Accelerator Cable Bracket Assy-Firewall Mounted / Obsolete
Fits: 1965 F100/250 352 2WD from serial number 672,001 & 1966 F100/250 352 2WD.
I found exactly one. I sent you an email with the info.
If I posted the info here, someone might beat you to it.
Old Feb 19, 2010 | 01:01 PM
carras's Avatar
carras
Thanks sir. Appreciate the help.
Old Feb 19, 2010 | 01:06 PM
NumberDummy
Check your email...I found exactly one.
Old Feb 19, 2010 | 01:17 PM
carras's Avatar
carras
Bill, got your note and I ordered the part. It's on its way here.
Thanks again!
Old Mar 19, 2010 | 08:55 PM
johninraleigh's Avatar
johninraleigh
Tonight the firewall bracket on the accelerator cable on my 1965 F100 broke. Had to drive home reaching under the dash and pulling on the cable housing by hand--great fun. Anyone know where can I get a replacement cable? Engine is a 390.
Old Mar 19, 2010 | 09:37 PM
William's Avatar
William
Accelerator Cable
I use LoKar. Works, easy to install, looks nice and wont cost an arm and a leg. Later you can add the kick down cable if you are shiftless.
Old Mar 27, 2010 | 02:02 PM
NumberDummy
C5TZ9A758AH .. Accelerator Cable / Obsolete/Reproduced
Fits: 1965/66 F100/250 2WD 352.
There was one of these on ebay recently. The seller/reproducer is Bob's F100 parts located in Corona CA.
Old Mar 27, 2010 | 04:48 PM
johninraleigh
Thanks, I did buy one from eBay (Melvin's) and it worked fine. The clamp that holds the cable onto the carb stud is a bit loose, but otherwise it was perfect. I bought a Holley stud kit, but it turns out I had the largest stud that would fit installed.
I am going to clamp it with some needle nose pliers to see if I can get it a bit tighter.
The part was expensive, but very good quality--essentially a perfect replica of the original.
Old Mar 28, 2010 | 04:18 AM
camperspecial65's Avatar
camperspecial65
Ive got a bracket if you need one...
let me know when you can.
- cs65
Dieseltorque
13
May 12, 2013 11:10 PM
48ATOY
Feb 24, 2013 07:07 PM
Chicago Fire Patrol
40
Feb 11, 2012 01:36 AM
Chicago Fire Patrol
20
Sep 19, 2007 06:57 PM
Red Star
Ford vs The Competition
Feb 4, 2007 03:50 AM
