To weld or not to weld?
Old Mar 24, 2010 | 09:17 PM
gogriz2009's Avatar
gogriz2009
I just ordered a new exhaust system for my 02 and I am struggling with the install? Should I have it done professionally and welded or do it myself? I have heard good arguments both ways but wanted your opinions. thanks for your input in advance. By the way i am going from stock to a 4" system. I would love to tackle it but want your honest input.
Old Mar 24, 2010 | 10:31 PM
EXv10's Avatar
EXv10
Not much to it unless you have to make bends.
Old Mar 25, 2010 | 05:49 PM
gogriz2009's Avatar
gogriz2009
Just a quick note. I was questioning your opinions on whether or not to weld. We don't go off road and I am wondering if the clamp system that comes with the kits is sufficient or if I should just take it to a shop? You all know what the shops told me, but i have read alot of posts where members have put them on with clamps and had no problem.
Old Mar 25, 2010 | 06:05 PM
howler4x4's Avatar
howler4x4
If the pipes fit together well, there's lots of overlap and the hangers are designed right clamps will work reasonably well. Tighten after a couple hundred miles. Check for leaks too.
OTOH, I've never heard of a good weld job leaking or coming loose.
If the pipes fit well, the intermediate solution is to clamp it and tack weld.
Old Mar 25, 2010 | 07:16 PM
X-Hibition's Avatar
X-Hibition
I don't know what you have on your rig or who manufactured your system, but I have a turbo-back MBRP that is clamped together. Since it is all SS T-304 I am always wiping down the pipes and have never seen a leak. I wouldn't weld mine together, but I have cat delete and muffler delete pipes and am still playing with what I like best.
The install was irritating and aggravating, but definitely do it yourself. I thought they had hardy, pioneer stock up there in Montana.
Old Mar 26, 2010 | 06:20 AM
inkertinker's Avatar
inkertinker
I just did a Banks system from the turbo back, all clamp together. After the down pipe it was a breeze. It also sounds much better than the straight pipe I had before.
Dave
Old Mar 26, 2010 | 07:16 AM
tdappleman's Avatar
tdappleman
If you use good clamps then you'll be fine. It gives you the option to do the install yourself plus do changes later without having to have it cut and welded again.
Old Mar 26, 2010 | 02:16 PM
gogriz2009's Avatar
gogriz2009
When you say "use good clamps" do you mean i should buy aftermarket clamps or use the clamps that come with the kit? Thanks again.
Old Mar 26, 2010 | 02:45 PM
X-Hibition's Avatar
X-Hibition
I used the clamps in my kit, most of which were specialized by incorporating the hangers.
Michael Mehegan
Feb 1, 2014 05:37 AM
kevin316
Aug 20, 2012 02:13 PM
Fair 96
Paint & Bodywork
May 19, 2006 01:48 AM
nuts4hotwheels
Exhaust Systems
Feb 21, 2005 11:19 PM
WhëëlMå1
17
Sep 2, 2003 02:05 PM
