Help me ID these parts Please
Hey guys i need help finding out what these two transmissions are and what the rear is.
Here is the rear:
Is this a 9 inch ford?
Here is trans 1:
It has "3H-D" in yellow on the tail shaft.
Im thinking its a 3 speed.
It also has a series of numbers on the driver side top
17 and then on a bracket it says"AF-7006-D"
What are the gear ratios?
Here is the 2nd trans, I need help with this one for sure.
What is that disc on the back for?
Here is what is says:
T89C-1A
WG DIV
Then the plate to the bottom right says 1-10
and there is a backwards "30" stamped into the casting. (this is at the bottom center
What is this and what does it do?
Thanks guys.
I hope you guys can help.
Also everything is for sale. (i am going to put in a 351w and 5 or 6 speed
trans.) I dont know what they are worth so be nice please.
Steve
Here is the rear:
Here is trans 1:
T89C-1A
WG DIV
Thanks guys.
Steve
AF-7006-D is not the trans ID number, it's the Ford ID engineering number for the transmission case...only.
The case was used in 1949/54 Ford/Merc passenger cars. The extension housing is also car only, because it has a flange on it for the car's transmission mount.
The Warner Gear T-89 3 speed manual transmission with the drum type emergency brake is not from any Ford that I know of.
The only vehicles I can think of off hand that used this combo were 1941/47 Studebaker M Series trucks with the 170 I-6 flathead.
Studebaker also used T-89's in some I-6 passenger cars from circa 1939 thru 1966.
Chrysler products (as noted) used drum type emergency brakes thru (at least) 1948. But I dunno what 3 spd manual trans' Chrysler used.
I'm only familar with their Fluid Drive and the Fluid-Matic aka Tip-Toe Matic semi-auto's (called Clunk-O-Matic by ppl back then).
51PanelMan: Are you in the Airflow Club? A pal of mine has a '34 De Soto Airflow sedan (it's light green) he drives to the GTG's.
thats awesome that its a dana 44. Those are suposedly really strong.
Can i get some more info on the two transmissions.
How do you know they are for car?
What is the difference between the car and truck transmission.
I will look for some more data tags/ numbers.
How much are these worth?
The truck's have the trans crossmember, but do not have a flange on the extension housing. Instead, there are two ears on the bellhousing.
Trucks have four trans rubber 'donut' insulators, two uppers, two lowers per side. One insulator fits in between the ear of the bellhousing and the crossmember, another fits below the crossmember.
A bolt goes thru the lower insulator, thru the crossmember, thru the upper insulator, thru the ear in the bellhousing, where a nut holds the whole tamale together.
AF-7006-D, the ID number on the case, cross references to Ford part number 1A-7006-A = fits: 1949/54 Ford Passenger Cars.
The 3 speed manual trans used from 1948 thru 1962 in F1/F2/F100/250's shares some parts with the cars 3 speed manual, but is a heavier duty unit.
While some Ford trucks had drum emergency brakes, I know of no Ford car or truck that used the Warner T-89.
Many moons ago, before I was a Ford partsman, I was a Studebaker partsman.
So I know that Studebaker cars/trucks used the flathead & OHV versions of the 170 I-6 engine along with the Warner T-89.
Some Studebaker trucks came with the Warner T-89 and the drum type emergency brake.
It's possible that the Warner T-89 with its drum type emergency brake is from a car, but what make of car...I have no idea.
Car or truck 3 spd
I have a 58 F100 panel with a 3 speed casing number 1A-7006-A. And I am shopping for a replacement or spare.
If I understand Bill's reply, mine may be a car casing.
I have found several AF-7006-D (case #) online and wonder how they are different.
Mikev58
Mikev58
Another great resource for transmissions is Van Pelt Sales, VANPELT SALES LLC - your ford flathead source since 2006
I'm not sure how "modern" of models he covers, but his knowledge is second to none.
The extension housing aka tailshaft (bolts to the case) is car or truck specific.
williamwilliam
213
Dec 20, 2020 03:20 AM
