1948 F-4 kingpins & bushings
Old Mar 9, 2010 | 08:22 PM
antique ford man's Avatar
antique ford man
Anyone know where i can get some NEW parts for a 1948 F-4 such as kingpins and bushings and and such. Any info. would be much appreciated.
Old Mar 9, 2010 | 09:51 PM
Old F1's Avatar
Old F1
No! But I sent a PM to Bill and he should be getting back to you soon.
Old Mar 10, 2010 | 12:38 AM
51PanelMan's Avatar
51PanelMan
Have you tried JobLot Automotive. I believe that they're in New Jersey. If they don't have any, try Chuck Mantiglia of Chuck's Trucks.
Old Mar 10, 2010 | 12:58 AM
Julies Cool F1's Avatar
Julies Cool F1
Are the F4 Kingpins different than the F3? Reason I ask is C&G lists a kingpin kit that is good for F1-F3. Wasn't sure if there was a difference!
Old Mar 10, 2010 | 01:05 AM
51PanelMan's Avatar
51PanelMan
There might be a difference. Weren't F4s considered one ton trucks, while the F2 was a 3/4 ton and F3 was a heavy duty 3/4 ton?
I know that the steering boxes are the same for F1-F3 trucks, while F4 and up are different. Might be the same for the kingpins.
Old Mar 10, 2010 | 07:48 AM
vintage tin's Avatar
vintage tin
i have a 50 merc m-68(=f-3),last summer i picked up a front axle off a 53 f-1to get the 5 bolt pattern for the front.i thought i could just swap the whole stub from the king pin out(didnt work).my 1 ton king pin was smaller than the 1/2 ton in dia.but the same in length.the axles where exactly the same so i just swapped the backing plates and hubs.
at the time i found a site that showed the specs,but that was before i figured out that i should be saving the links and how i cant remember where it was.
i think dennis carpenter lists the different ones or lmc,but not sure.they are the same length for sure but different in dia.just make sure you order the right size.
hope this helps.
Old Mar 10, 2010 | 08:17 AM
petey shoes's Avatar
petey shoes
joblot is in queens, ny. they probably have what you need. lots of stuff for the bigger trucks. have them send you a catalog.
Old Mar 10, 2010 | 08:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by antique ford man
Anyone know where i can get some NEW parts for a 1948 F-4 such as kingpins and bushings.
Welcome to FTE
B3T3111A .. King Pin Kit / Obsolete / Fits: 1948/52 F4/F5/F6 // 1953/56 F500/600
AITKEN MOTOR CO. in Aitken MN has 1 = 218-927-2169.
DOTTS MOTOR CO in Clearfield PA has 1 = 814-765-9681.
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 800-546-7278.
ANTIQUE AUTO SUPPLY in Arlington TX has 11 = 817-275-2381.
Old Mar 10, 2010 | 12:17 PM
antique ford man
You guys are the best. Thanks for all the help.
Old Mar 10, 2010 | 08:17 PM
HT32BSX115's Avatar
HT32BSX115
Howdy,
I bought 0.010" over size kingpin kits from Napa auto parts for my 55 F-600. A standard pin would have been sloppy in it. They came from Rare Parts in Stockton, Ca. Steering & Suspension, All American Cars, Import Cars, Off Road and Trucks | RareParts.com
I then used a front end shop to install them because they were able to ream and hone the holes with a Sunnen hone. The front end is like new now.
The steering is absolutely perfect now.
cadougherty_67
Mar 29, 2017 04:04 PM
3twinridges
Sep 18, 2016 06:34 PM
JJS72XLT
Dec 2, 2012 06:29 PM
Nick_Good
Mar 2, 2010 06:06 PM
aussie70
Sep 27, 2007 05:37 PM
