1978 - 1996 Big Bronco
Screwy Fuel Sender
Old 03-09-2010, 05:19 PM
T Tom's Avatar
T Tom
T Tom is offline
Screwy Fuel Sender
I ordered a new fuel tank for my 88 Bronco about a year ago and purchased a new fuel sender as well. My Bronco has the fuel pump on the rail with a small pump on the sender as well, 2in hole. Tank has been fine but my fuel gauge has been acting odd ever since. I drive it occasionally and since it had some old gas in the tank I decided to pull it Friday evening and drained it and pulled the sender to check it out. I hooked the sender back up to the three prong plug so I could mess with the float and see what it was reading. When I did it turns out that E (empty) reads as F (Full) and vice versa. I took a look at the sender thinking you could obviosly just swap it over but the mount for the sender is welded to the pickup tube?
I thought about odering a new sender but when I look at them online they look identical to this one the only question is are they on the inside? Is it possible that I ordered a pickup for another year? anybody know a fix short of grinding off the plate and welding on the other side? Now I wish I had kept the old sender to compare.
Old 06-02-2010, 04:47 AM
g_k50's Avatar
g_k50
g_k50 is offline
Read the directions, connect sender properly. 1990 fuel pump unit in my garage with wiring colors explained. Bumping it.
walt1968
08-15-2014 08:59 PM
cchvacman
08-10-2014 03:30 PM
dynamic
07-09-2012 10:25 AM
carlsson
1999 to 2016 Super Duty
02-20-2012 05:14 AM
924x2150
18
08-29-2005 09:49 PM
Quick Reply: Screwy Fuel Sender
